- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router issue - dropping signal every 5 minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router issue - dropping signal every 5 minutes
sounds like its in a boot loop.
Are you able to access it at any point during this?
Try reinstalling the firmware on it in case the firmware is corrupt. Then do a factory reset/reinstall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Are you able to access the routers login info?
if so, follow the guide above
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
try downgrading the firmware a version. See if that helps. Maybe there's an issue with that version of the firmware on your device
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
downgrading is pretty easy.
You follow the manual firmware update process and instead of using the newer firmware, you just use the older version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Download the firmware onto a pc/laptop with the pc/laptop directly connected to your modem/gateway.
Then hardwire that device into the router and follow theprocess.
