- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WIFI Button Nighthawk X10 (AD7200)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to know if there is anyway to set wifi on/off button to disable guest network only. That way the admin people can continue to use internet while easily turning off guest access without using the interface, just simply pushing the on/off button
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not the button, but you don't have to use the graphical user interface (GUI).
genie | Product | Support | NETGEAR
The Netgear genie for your operating system can do it. So can the Nighthawk app.
Not as simple as pressing a button, but easier than firing up a browser.
The app can even do it remotely.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WIFI Button Nighthawk X10 (AD7200)
ok so I just down load the app and do it from my phone
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may need to set up Anywhere Access on the router before that works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok thank you
also I have two different nighthawk setups, one at work (x10) one at home (x8) will the app run them both independently or will it be confused
- Mark as New
- Bookmark
- Subscribe
- Permalink
That should work OK. I use the app to control two different routers on two separate networks.
When you are in wifi range of a router it connects to that. When you are away from the router it connects over the Netgear cloud through Anywhere Access.
If you want to check these features in the manual, you may have ti read up on Remote Management. Netgear changes the name.
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
i can do that tommorrow ... a bit off topic what do we call the setting for reserving time for a device that connects ... I need to reduce that down to 2 hours
- Mark as New
- Bookmark
- Subscribe
- Permalink
also can an assistant use the app under his own account and do the same things through anywhere connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
So off topic that I don't even understand the question.
What device connecting to what and how?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I apologize, sometimes I get so vague, cause I can't remember what I knew so I try and describe it in common terms. What I meant to ask is where to find DHCP. In my home network I use DD-WRT so my netgear firmware is not there, just could not remember the terminology. Found the term at 2 am. Today I will open up interface and see if I can find the settings in LAN. I'm over 70 yrs old been a few years since I've done this, if you don't use it you lose it. thanks for your patience, all you all
- Mark as New
- Bookmark
- Subscribe
- Permalink
You won't find much expertise in that around here. Netgear doesn't support third party firmware – it breaks warranties – so expertise is thin on the ground.
I'm over 70 yrs old ....
Snap. This is usually when we start to reminisce about programming in Fortran or, depending on your origins, Cobol.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yepper did that in the late sixties early seventies, that was light years ago in the computer world, whole different ball game today.
Sooo Thank you for all your help, everything worked, both of us access the system through Anywhere Access and turn on and off the guest wifi as needed, DCHP is set for 2 hours and life is great. Wahoo you all made me look good today, keep up the good work
