- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Downgrading firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Because of DNS issues in the latest revision, I am trying to downgrade my firmware from V1.4.2.84_1.3.42 to R7900P-V1.4.1.62_1.3.22.
I select the .chk file but after a few seconds of uploading it says connection reset and nothing else happens. What am I doing incorrectly?
Rob
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7900P X6S AC3000 Latest Firmware v1.4.2.84 Destroys DNS resolution
Where on earth is Netgear in this debacle? This has been an issue for months. I still get "DNS_PROBE_FINISHED_NXDOMAIN".
Now it is not only impacting webrowsing but I suspect another application that uses DNS.
It is hard to believe that a company for whom this is core business has not fixed this yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you'll need to downgrade to prior FW version or what worked for you.
Now it is not only impacting webrowsing but I suspect another application that uses DNS.It is hard to believe that a company for whom this is core business has not fixed this yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did downgrade to V1.4.2.84_1.3.42 with the help of netgear support. But I am now still getting the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
v.84 is the recent version of FW so you'll need to downgrade to something older then this version. Try v.62?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get a connection reset shortly after beginning upload of either 62 or 66 to the router. Any ideas? What might I be doing wrong? And thanks for the help.
Rob
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might start your own post instead of jumping on someone else's thread and potentially getting your info confused with the OP's.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure thing. My apologies. I will figure out how to do that. I understood that responses were volunteer community.
Rob
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser are you using? Try MS Edge or Firefox.
Be sure to clear out all browser caches before entering the routers web page.
You might try a factory reset first, get thru the setup wizard, then go directly in and try the FW update.
Be sure you are unpacking the FW .zip file before you select the actual FW file to send using the routers manual update page.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used MS Edge after clearing the cache. While it is uploading and then goes to a white page saying connection reset, if I wait an extended period of time to you suspect that it may actually finish? it simply seems to blank in the middle.
I am reluctant to reset the router as so much in the house relies on the wireless network that it would take a while to bring it back.
ROb
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try Firefox.
Possible that the router is some odd state which maybe need a reset.
You can do this first:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much for taking the time to help me on this. I really appreciate it. You were correct. I did reboot the router and it did enable me to go back a rev on the FW. I went back to 68 on my R7900p. I will try that first and if necessary go back further to stop the DNS timeouts.
Once again many thanks.egards,
Rob
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did discover one problem. I believe I had taken the FW back a rev with the help of Netgear support. Having been able to take it back again myself I have discovered that updates are enabled. It probably did update back to the errant rev.
Sadly when I change it to disabled and hit apply no other button is usable even logout. Nothing visible happens other than admin seems to freeze. I have to restart the router although it does process outside web requests. Would I be imposing too much on you for suggestions for that if you have any?
Rob
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF v.84 got back on, then you'll need to manually download v.68 on to your PC. Probably factory reset the router. Then disconnect it from the ISP modem. Get thru the setup wizard and select manual setup or setup myself. Get to the home page and manually sent the v.68 FW file again. After it's back to ready. Go in and disable Auto udpate FW option. Once this is set, re-connect the router back to the ISP modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am successfully back to Version 68 with updates disabled.
What puzzles me is that the "No_Domain" issue is at least two months old and it seems like going back a rev fixes it. So their developers have an exemplar of what worked. Unless the changes were incredibly extensive I would have expected a decent development team to have fixed the issue by now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WEll with all thats been going on in the world, things change and development and test have been impacted. NG is aware of the issues. May take time for them to get things fixed. Be patient.
Glad you got it working.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
