Orbi WiFi 7 RBE973
Reply
Which WiFi extender compatible with Nighthawk X10 AD7000
vicorly2
Follower
I would like to extend my WiFi from my Nighthawk X10 AD7000 via Ethernet to a Netgear WiFi Extender in another part of my house. Which Netgear model should I buy?
Model: R8900|Nighthawk X10 AD7000 Smart WiFi Router
Message 1 of 2
Guru
Re: Which WiFi extender compatible with Nighthawk X10 AD7000
Netgear makes a lot of differnet extenders.
with such minimal info it tough to help.
there is a product finder on the the extender site that allows you to narrow the search by speed/features you want.
https://www.netgear.com/home/wifi/range-extenders/
Just make sure to get one that supports access point mode as that'll be the mode you need for hardwired connection
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 596 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
