- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
can not login disney+ with nighthawk r7960p
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi, i have att bgw320 gateway service as modem, r7960p as ip passthru router. It works for few years with disney+, then it stops working for a month now. It is connected to r7960p wifi. Other services work fine like netflix, video prime, discover+, but not disney+. if i use bgw320 wifi, then it works fine with other streaming services. I tried to reinstall disney app on firestick, smart tv, it is still failed with login error. Even i login disney on website via r7960p wifi, it is failed too. I did not change anything in this r7960p for last 4 years. Please let me know any solution for this problem. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: can not login disney+ with nighthawk r7960p
Try a different DNS Server. Here's a few. Also remember to change the ipv6 dns server if ipv6 is enabled.
CloudFlare
IPv4: 1.1.1.1 and 1.0.0.1
IPv6: 2606:4700:4700:0:0:0:0:1111 and 2606:4700:4700:0:0:0:0:1001
GoogleDNS
IPv4: 8.8.8.8 and 8.8.4.4
IPv6: 2001:4860:4860:0:0:0:0:8888 and 2001:4860:4860:0:0:0:0:8844
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for reply, i just want to make sure before i crew it up. So i go to my ip passthru r7960p router to set dns server as you give it to me, then every devices connect to this router can login disney plus, right?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
no, it did not work, just something wrong between netgear r7960p and disney plus server. Now I just watch disney plus using att gateway, it works fine, just no DLNA. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried the R7960P with the ISP gateway using it's DMZ or IP-passthru for the router while it's in router mode?
Or configure the R7960P for AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try putting the router in to AP mode or a complete factory reset and setup from scratch.
AP mode should be able to connect and log into Disney here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried AP mode on the R7960P to see if the DLNA option is there. I think some routers support this, even in AP mode.
Sounds like something between the ISP router and R7960P is getting block for the Disney service. The IP Pass thru should work to fix that however may not do what you need to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF DLNA is enabled while in AP mode, you might give this a try.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
problem is not dlna, it is about disney plus login via r7960p router wifi under att router wifi with ip passthru set up, that is problem, i do not think there is solution in this forum, thanks anyway
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hard to know unless you try.
Hopefully you'll find the fix.
Good Luck though.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
