Reply
my wifi router changed?
Imnotmagic97
Follower
It seems some other users were having the same problem as me, but I don't know about this one. My whole wifi router had changed its name to BERNIE_RAX48 and it could see it on avaible networks but wouldnt let me join it for some reason. I don't know if someone had gotten to it possibly hacked it? Not really a whiz on this all i know is just how to set up the router.
Message 1 of 3
Re: my wifi router changed?
Is that the wifi SSID?
What happens when you try to connect? Any messages you get?
Any chance that this SSID comes from the neighbours? Is that the only SSID you see?
Do you own a RAX48 router?
Have you tried changing the SSID that it puts out? You should be able to do this.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Guru
You can always hardwire into your router and see/change your ssid.  This bypasses needing the network name/password.
Maybe someone else has the same router. Or maybe someone did change it.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 263 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
