Orbi WiFi 7 RBE973
Reply
prot forwarding
cydrollinger
Follower
prot forwarding
I am not sure the model number is absolutely correct. An R9000 Nighthawk X10.
I am trying to get a couple of devices port forwarded out to the internet, accessibe to anyone.
1. acess the router web application
2. setup static IP on the device
3. advanced setup port forwarding
      create custom service for static ip device port 80 http server tcp/udp
4. check port forwarding online says the internet IP address assigned from ISP over port 80 closed.
I have checked uPnP on off up down
ihave disconnected the usb ready share
I have rebooted the router
I have noticed that remote management is not on and has a different port
I have searched the network for another router
I am a loss why I can not port forwad from the Netgear router
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: prot forwarding
> internet, [...]
   That's a little vague.  Also, "port forwarding" is best thought of as
the special handling used for an _incoming_ message, _from_ the
Internet.
   Do you mean Address Reservation?
   Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address.  Either one should fix the address of a
device, but some implications are different.
> tcp/udp
   Again, a little short on details.
   For the usual problems with port forwarding, see:
      https://community.netgear.com/t5/x/x/m-p/1859106
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 295 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
