Orbi WiFi 7 RBE973
Reply
r7000 drops internet connection
culero23
Tutor
Re: r7000 drops internet connection
Thank you for posting this. I will try not to upgrade to the latest firmware. I'm afraid my router will start having issues again.
Message 26 of 29
JamesGL
Master
Hi gavster,
After you reset the router, did you manually reconfigure the router or loaded the back up settings?
Message 27 of 29
Shawkat
I agree to all R7000 is without a doubt a faulty product. I have bought this product 4/5 months back and ever since this has been problem. I have upgraded to the latest firmware and have done factory reset several times but the it constantly drops connection almost every 20/30 mins. I use Linksys EA4500 as a back up router which works like a charm. I have done lot of research on this product and tried many suggestion I could find without any luck. I diont think Netgear can ever convince me again with their fancy words to buy their product again.
Message 28 of 29
doraemon
Prodigy
Mine still works.
Message 29 of 29
Top Contributors
Discussion stats
Announcements
Orbi 770 Series
