Orbi WiFi 7 RBE973
Reply
AC 1200 Smart wifi router with external Antennas Model R6220; Firmware Version V1.1.0.110
CapJT
Based on an email received from Netgear on/around 09-October-2021, I updated the firmware of my Netgear router Model R6220 to the latest. (Previous updating was as per their recommendations vide email of around 27-March-2021)
However since the last updation of my router (ie since about 09Oct2021), seemingly I am unable to Access Netflix and Prime Video using my Amazon Fire stick and Mi Box 4K Firestick, when connected using my existing Internet service provider MACH1).
(Prior to 09Oct2021 for atleast the past about 2 years, both the fire sticks have been streaming both Netflix and Prime video using the same service provider.) The connection subscription is with fibre cable and speed of 100 Mbps. (Last speed check indicated download speed as 95.92 and upload speed as 74.52 Mbps.)
The said programmes ie Netflix and Prime video can be accessed by me directly on my mobile phones and Laptops through my existing internet service provider, however on the firestick (while using internet connection from my service provider) NETFLIX shows the error
"Netflix has encountered an error Code:NW-2-5"; and Prime Video shows the error "Internet Connection Error - We're unable to connect to Prime Video. Please verify your device's Internet connection. Error Code PLR_PRS_CALL_FAILED”.
On each of the Firesticks, I can access YOU TUBE using the service providers Internet connection.
When I connect each of the fire sticks using my Mobile service providers Internet connections (Airtel/VI & Jio) I am able to access both Netflix and Prime Video easily.
I have contacted the customer care at Amazon/Prime video who say that as the sites Netflix and Prime Videos are accessible on the fire sticks using the Mobile phone service providers/ networks, hence the fire sticks therefore are seemingly OK.
My Internet service providers also say that as the relevant sites Netflix and Prime Video can be accessed on the Laptops and Mobile Phones using their internet service directly, they suspect something could have affected either on the fire sticks or on the router settings.
We have also rebooted/factory reset each of the firesticks and reentered the amazon username and passwords, but still the problem remains.
Hence we request for your advice if anyone has faced a similar problem and seek advice how the same was overcome.
Please advice
Message 1 of 14
Guru
Re: AC 1200 Smart wifi router with external Antennas Model R6220; Firmware Version V1.1.0.110
Are you using IPv6?
What modem/gateway is it connected to?
Message 2 of 14
CapJT
Hi, Tks for ur response;
As far as I can ascerttain from the service provider
Are you using IPv6? - Yes as informed by the service provider
What modem/gateway is it connected to? - Broadband 100 Mbps - Fibre cable connected to
Router Netgear AC 1200 Smart wifi router with external Antennas - Model R6220
Message 3 of 14
Guru
Are you using IPv6? - Yes as informed by the service provider---Is it enabled in your router? Thats the key.
Router Netgear AC 1200 Smart wifi router with external Antennas - Model R6220-----The R6220 isn't an ONT ( the fibre connects to something the router connects to)
Message 4 of 14
CapJT
Hi Sir,
Thanks again for your response;
Sir can you advice how I can verfiy this on my router R6220
Yes indeed ; the fibre is connected to a SEE (subscriber end equipment - which is marked as Ipv6 ready - Make/Model: Optilink /
(OP-XONT 71000)) which inturn is connected to the router.
Message 5 of 14
CapJT
Further to my above attached is the screen shot of the IPv6 status as seen in my screen; Persume Ipv6 is engaged.STATUS OF Ipv6 as seen on my routerSTATUS OF Ipv6 as seen on my router
Message 6 of 14
Guru
photos have to be approved by a moderator and it can take a while. if you click on "choose file" and add it that way, we can see it right away
Message 7 of 14
CapJT
Tks, Noted.
Doc Attached as per suggestion of ur good self
Message 8 of 14
Guru
Your photo shows you have it disabled. On the right, click on the drop down box and go to auto detect. Then apply
Message 9 of 14
CapJT
Thanks your of 2dy.
As suggested we have enabled Ipv6,;
However No improvement has been seen; All 3 viz. Prime video, Netflix and Hotstar all indicate Internet connection error (when tried out using fire stick).
Considering that wifi connections were indicating network connection errors, we procured
locally an Amazon Ethernet adapter for Amazon fire TV stick and connected it up to the firestick.
Despite direct network connections and the connection status indicating NO ISSUES (even over wifi it was the same),  the Prime video, Netflix and Hotstar when tried out using fire stick all indicate Internet connection error.
Please advice
Message 10 of 14
Guru
If it happened after a firmware update, have you tried downgrading the firmware?
Message 11 of 14
CapJT
Yes Sir,
rebooting/factory reset of the present router and/or trying out with another
router (TP Link which I also have),
I would like to keep as the last option/resort since that could also require
involvement of the Internet service providers for re-feeding and/or resetting
the account parameters at the router end and/or at the exchange end.
Thanks to all for all the assistance/suggestions provided to me till date;
Request you to kindly let me know if any other ideas come up of a soloution
to this problem;
Thanks again for all your assistances
Message 12 of 14
Guru
Downgrading the firmware on the R6220 doesn't require anything on the ISP's end. Its all user driven for that device. You simply download the older version of the firmware and manually install it to the router.
Message 13 of 14
CapJT
With my ISP technician was in attendance today,
we first reset the Netgear router to factory defaults, but on restarting we found that all
three ie. Netflix, Prime video and Hotstar still displayed the same Internet Connection Error, when connected with each of the fire stick .
The technicians suspect some problem with the Router.
with some probable DNS mismatch with the fire sticks, the cause of these problems;
Anyway since this problem has been going on for too long (since about the 9th or so)
we decided and replaced the Netgear router with a TP Link router (which was already
with me).
With this TP Link router, we are able to access all required programmes using each of the fire sticks.
As of this present time time and patience of my kids was running out and hence change
of router was the best option.
The Netgear router is still operational, (without Netflix etc. from fire stick), and as time
permits we shall continue to tinker around and experiment with this Netgear router,
and surely a soloution can/will be achieved.
We thank you all for your  patient assistance and for all your efforts;
Thanks again
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 1095 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
