Orbi WiFi 7 RBE973
Reply
Nighthawk R7000
masample
Follower
Nighthawk R7000
Firmware Version
V1.0.11.128_10.2.112
When using the web browser on the basic home tab, I see there are 23 attached devices. Selecting the attached devices tab, I only see 10 devices. Anyone having simular issue
Message 1 of 5
jiceman
Tutor
Re: Nighthawk R7000
I am using the same firmware and have the same issue.
Model: R7000|AC1900 Smart WIFI Router
Message 2 of 5
jiceman
Tutor
Re: Nighthawk R7000
Also, in only see the subset of devices in the Nighthawk app. But, in the old Genie app, it shows many more (maybe all) devices.
Message 3 of 5
jiceman
Tutor
Re: Nighthawk R7000
Also, if you look at the access controll tab, you may see more devices listed. Maybe a possible work around.
Message 4 of 5
AugerSt
Re: Nighthawk R7000
Hello,
Same issue and I had to reset the R7000 with the reset button on the back of the device (device on, keep it pressed for at least 5s). I think the problem comes from this firmware.
Warning : doing this, you will loose all the settings : router mode, wifi id and password ...
SA.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1109 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
