Orbi WiFi 7 RBE973
Reply
Nighthawk Router R8500 - Being targeted every second by 193.142.146.215. How Netgear protects me?
Adisus
Follower
I purchased about 6 years ago a Nighthawk Router R8500 as it was the best I could have purchased. It has the latest firmware installed. For about a week I noticed that my Windows 2016 Server is being hit every second by 193.142.146.215, as per the Event Viewer - Security list. I understand that the Firewall is hidden from the user and no user settings are possible. Is there any function belonging to the router which allows blocking incoming/inbound access based on IP addresses? Is there anything I can do besides getting a different brand? Thank you
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk Router R8500 - Being targeted every second by 193.142.146.215. How Netgear protects...
No, this router does not have advanced firewall settings you can change to prevent this.
DarrenM
Message 2 of 2
All Replies
DarrenM
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 800 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
