Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 GUest netowrk not obtaining ip address, secured connection works fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-07-13
03:16 PM
2016-07-13
03:16 PM
Like the subject states. If I get on the secured wireless internet works fine. Guest account I can't access internet or get ip address. Just started today. Using firmware version V1.0.3.56_1.1.25.
I disabled and re enabled the guest accounts but did not fix.
Solved! Go to Solution.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Labels:
Accepted Solutions
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-07-13
03:25 PM
2016-07-13
03:25 PM
reset to factory defaults and start over or try a newer FW version, there are 7 updated versions
Message 2 of 4
All Replies
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-07-13
03:25 PM
2016-07-13
03:25 PM
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-07-14
11:17 PM
2016-07-14
11:17 PM
Re: R7000 GUest netowrk not obtaining ip address, secured connection works fine
Updated firmware. Problem fixed. Thanks.
Message 3 of 4
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-07-15
06:13 AM
2016-07-15
06:13 AM
You're Welcome!
Message 4 of 4
Announcements
