Orbi WiFi 7 RBE973
Reply
R7000 keeps turning on and turning off
WffNet
I can't even use my inter for 1s. My stupid R7000 just keeps on and off again and again with no stop! BTW there's a click sound when it turning on and off.
Message 1 of 4
Accepted Solutions
VE6CGX
Master
Re: R7000 keeps turning on and turning off
Sounds like power adapter problem. Make sure it is plugged in firmly on router. Try another wall outlet too. If still doing it, then you gotta try another adapter. Also make sure the on/off switch on the router is working right (it is known to go bad). Just  gently jiggle it around to see if it makes things worse or better.
Message 3 of 4
All Replies
WffNet
Message 2 of 4
VE6CGX
Master
Message 3 of 4
WffNet
It works after I plug it to another wall outlet. Thank you so much!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 9158 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
