Orbi WiFi 7 RBE973
Reply
Swap Frontier router with Nighthawk X10
MelJim
Guide
How do I go about swapping my Frontier Fios router to the Nighthawk X10 R9000?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 7
Accepted Solutions
Guru
Re: Swap Frontier router with Nighthawk X10
thats a gateway/router combo device. Meaning its needed to connect to your frontier setup as a modem at minimum.
You can put it in bridging mode or IP passthrough mode.
that sets it up as a modem only device. Then you'd simply connect the R9000 to it and set it up as normal.
Or you can contact frontier to see if they have any modem only devices or whats compatible with their service for modem only devices.
Message 4 of 7
All Replies
Guru
What frontier router is it?
If its a simple router, it shouldn't be hard.
But if its a gateway/router device, then you might not be able to.
Details are key here.
Message 2 of 7
MelJim
Guide
My apologies, the Frontier router is an Arris model NVG468MQ.
Message 3 of 7
Guru
Message 4 of 7
MelJim
Guide
My apologies, the Frontier router is an Arris model NVG468MQ. It is only being used for internet. No voice service, etc.
Message 5 of 7
MelJim
Guide
Thank you
Message 6 of 7
Guru
Good luck!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2922 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
