Orbi WiFi 7 RBE973
Reply
r6900P Wired Ethernet Speed is extremely slow
Sparky66
Tutor
Replaced ISP provider router with Nighthawk to improve wifi coverage.  Wired and Wifi speeds are dismal at best.  If I plug directly into ISP ethernet speeds are: 866.06 Down and 519.37 up.  Wired through the nighthawk ethernet speeds are: 182.31 Down and 196.64 up. Running Windows 10 etc.  I have Qos disabled, Traffic Meter disabled, access control disabled.  Firmware version updated upon install: V1.3.1.44
Any assistance would be helpful!
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 5
Accepted Solutions
Sparky66
Tutor
Re: r6900P Wired Ethernet Speed is extremely slow
For all those struggling with reduced download speeds...
I chatted with support and they graciously sent me a new router after much discussion and a few tweaks to MTU with no success.  Upon receipt of the new router I plugged it in, turned it on basically matched my hardwire speeds out out of the box...  See pics below.  Over night router updated to most current firmware which was Version 1.3.1.44.
After the update I was back to 25% speed compared to straight ethernet to my ONT device.  So I reverted the firmware back the version that the replacement router came with (R6900P-V1.3.0.20_10.1.1) and no issues...
Version 1.3.1.44Version 1.3.1.44R6900P-V1.3.0.20_10.1.1R6900P-V1.3.0.20_10.1.1
Model: R6900P|Nighthawk Smart WiFi Router with MU-MIMO
Message 3 of 5
All Replies
Sparky66
Tutor
Anyone experiencing this...?
Message 2 of 5
Sparky66
Tutor
Message 3 of 5
vanmike
Yes I'm having the same problem... about 1/4th the wireless 5G download speed compared to wired connection. Is reverting the firmware my only option?
Message 4 of 5
myersw
Master
Glsf to hear the replacement is doing the job.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3654 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
