- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can only reserve 3 IP addresses
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router will only allow me to reserve 3 IP addresses. When I go to add a fourth, it deletes one of the 3 previously reserved addresses and adds the new one.
Comments or suggestions please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can only reserve 3 IP addresses
@TheComputerHyp wrote:My router will only allow me to reserve 3 IP addresses. When I go to add a fourth, it deletes one of the 3 previously reserved addresses and adds the new one.
Do you have sufficient IP addresses available in the DHCP pool?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK
Some pretty standard questions below.
What is the brand name and model number of the modem/ONT upstream of the router?
What is the version of the firmware you have on your RAX80? The "Latest" is not an answer. Only a version number will confirm the answer.
Are you trying to make this configuration change over a mobile device or a computer? If a computer, how is it connected to the router? Via Wi-Fi or an Ethernet connection?
Recently, have you powered down your router (pulled the power cord), waited for one minute or more, then restarted?
Does your ISP support IPv6? Do you have it enabled in your configuration?
For your existing IP reservations, are you using spaces or special characters in the device names?
When you last updated the firmware on your router, did you perform a firmware default reset and configure from scratch? Import a previous configuration file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Arris SBG6580-G228
V1.0.10.140_2.1.46.1
Computer connected to router via Wi-Fi
Yes
Does your ISP support IPv6? Do you have it enabled in your configuration? IPV6 disabled
For your existing IP reservations, are you using spaces or special characters in the device names? No, but why does that matter. The user manual makes no mention of limitations for device names.
When you last updated the firmware on your router, did you perform a firmware default reset and configure from scratch? Import a previous configuration file? I did a firmware default reset and configured from scratch (learned of this design flaw the hard way when I imported a previous configuration file with the last FW update and couldn't connect to the internet)
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TheComputerHyp wrote:What is the brand name and model number of the modem/ONT upstream of the router?
Arris SBG6580-G228
Yes
Your Arris SBG6580 is a combination modem/wireless router device. These are often referred to as a gateway. When you connect your RAX80 wireless router downstream, you have a LAN situation referred to as a double NAT. The double NAT means two separate devices are trying to simultaneously assign IP address to devices on your LAN and you end up where you are now. You can read about it here: https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad.
There are several options to correct the situation. Do a little research. I recommend you configure your SBG6580 as a modem only (bridge mode) and use your RAX80 as your LAN router. Primarily because it has the new AX band for Wi-Fi.
Although the manual does not mention limitations on device names for reserved addresses, playing cute (spaces and special characters) is an invitation for problems. When you get your double NAT situation corrected, if the IP address situation is not corrected you need to get rid of any device names with spaces or special characters.
If your ISP supports IPv6, recommend you enable it on your new router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I already have the Arris modem set up as a modem only, so I have no double-NAT problems.
My IPS (Sparklight) does not offer IPV6 connectivity, and I have IPV6 disabled on my router.
I will go through my attached device's names and remove all spaces and underscores and will report back to this post if that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TheComputerHyp wrote:I already have the Arris modem set up as a modem only, so I have no double-NAT problems.
Be sure and do a full power down (adapter disconnected) then restart your router after making the revisions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@iyang wrote:Hi @TheComputerHyp ,
What's browser do you use ?
Thanks
Primarily Firefox. I also keep IP address bookmarks in Edge as a backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not understand your questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
