Orbi WiFi 7 RBE973
Reply
Re: Armor blocked a site on v3.2.15.25 and never forgot it
ekhalil
Master
After upgrading to FW v.3.2.15.25 and activitating Armor, I got a warning that a site was blocked because it was suspected for some reason.
I checked the site and I knew that it was a safe site (it's the server for my IPTV provider) so I set it to "unblocked" in Armor, but that did not help to allow me to reach the site.
I disabled Armor but that didn’t make a difference.
I factory reset Orbi, and even that did not help. I then downgraded to FW v3.2.11.2 but still the site was getting blocked and my IPTV was not working!!
When I connected directly to the ISP router I could reach the site and my IPTV was ok, and if I connect via my iPhone I could reach the site, but not via Orbi.
When I changed to my old Orbi RBR50, the site was reachable and my IPTV was working!
For some reason the settings is sticking in Orbi AX and not possible to remove even with full factory reset. Very wired!
Message 1 of 4
Guru
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
Thank you.
Message 2 of 4
Christian_R
NETGEAR Employee Retired
Hi ekhalil,
Thanks for sharing. Would you mind letting me know how you disabled Armor (GUI or Orbi app)?
Thanks,
Christian
Message 3 of 4
ekhalil
Master
Hi Christian,
I used the app to disable Armor.
Strange that the issue disappeared after 2 days by itself. My analysis is that it just took time to update the iptables after disabling Armor? I really don’t know how Armor works.
Thank you.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1993 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
