Orbi WiFi 7 RBE973
Reply
Connect router and satellite by ethernet cable
Jan777
Follower
Hello
When you have two buildings, is it possible to connect a satelite by ethernet cable to the router? (cable length 130 feet)
Thank you in advance.
SXK80B4 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
Message 1 of 2
Guru
Re: Connect router and satellite by ethernet cable
Yes you can. They support wired backhaul.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 473 views
  • 0 kudos
  • 2 in conversation
Announcements
