Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
Multiple WIFI network on an ORBI
Cyrilblanc
Hello
Orange keeps changing the name of my two WIFI network 😫 so my Alexa is down each time.
I have about 80 devices so there is no question I have to change the setting of those devices each time that Orange is resetting my WIFI names
My Idea is to add this two WIFI network to my 3x ORBI
I need to add a 5GHZ and a 2.4 GHZ Wifi Network with a different already defined name
Is it possible ? how ?
Thanks in advance for your help
Best regards
Cyril
Message 1 of 7
Accepted Solutions
Cyrilblanc
Re: Multiple WIFI network on an ORBI
Hello
I have found that you can have 3 x WIFI network that have 2 x SSID, one for 2.4 and one for 5 ghz
Netgear send a note today about 6 ghz
Message 7 of 7
All Replies
CrimpOn
Guru
It would help to know the components of this network:
  • The Internet Service Provider is Orange, correct?
  • What equipment has Orange provided?
  • This Orange equipment broadcasts WiFi channels, and Orange changes the WiFi name (SSID) of these channels?
  • There is a Netgear Orbi system connected to the Orange equipment?
    (specific model numbers would help)
  • What 'mode' is the Orbi system set to? (router or access point?)
I love my Orbi.
Message 2 of 7
Cyrilblanc
Hello
My replies are Bold CAPS.
  • The Internet Service Provider is Orange, correct? YES
  • What equipment has Orange provided? ROUTER ON FIBER
  • This Orange equipment broadcasts WiFi channels, and Orange changes the WiFi name (SSID) of these channels? YES
  • There is a Netgear Orbi system connected to the Orange equipment? YES ORBI PRO WIFI 6
  • What 'mode' is the Orbi system set to? (router or access point?) ROUTER
Hope this help
Thanks
Cyril
Message 3 of 7
Guru
Orbi doesn't support having separate SSID names.
One system that does support separate SSID name is the Nighthawk MK series MESH systems.
@Cyrilblanc wrote:
Hello
Best regards
Cyril
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 4 of 7
Cyrilblanc
Hello
Thank you very much for your answer.
I just had an idea : can you define the "WIFI invited" as a 2.4GHZ connexion
If no :
- Do you know another router that is not "mobile" ?
Best Regards
Cyril
Message 5 of 7
Guru
Message 6 of 7
Cyrilblanc
Hello
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1661 views
  • 1 kudo
  • 3 in conversation
Announcements
