Orbi WiFi 7 RBE973
Reply
Orbi pro SRR60 Displays Error in Red below the Internet connection in AP Mode
JeffFerg
Guide
Please let me know how to correct the situation. Router works in AP but displays the Red Error. Thanks.Red Error Message.jpg
Message 1 of 10
Accepted Solutions
Guru
Re: Orbi pro SRR60 Displays Error in Red below the Internet connection in AP Mode
Glad you got it figured out!
Might mark it solved so others aren't still trying to fix it when you've figured it out.
Message 8 of 10
All Replies
Guru
do you have your Internet connection connected to the wan port on the router? Or the lan port?
What router is it connected to?
Message 2 of 10
JeffFerg
Guide
Thanks for your reply. Yes, the feed from one of the SonicWALL router's LAN ports goes to the WAN port of the Orbi SRR60 in the AP mode. Even though the Internet connection displays the BIG RED sign of "ERROR",  the Orbi in the AP mode provides correct connectivity to devices connected via Wi-Fi. I have connected another SRR60 Pro as a test and it also shows the "Big Red Error" and it also works. Furthermore, I have tested the setup with an Asus, TP and D-Link routers in AP mode, all of them show the Internet connection correctly, not in Red.
Is there some Error in the Orbi SRR60 Pro Firmware or configuration?
Thanks,
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 3 of 10
Guru
wonder if its something in the sonic wall that blocks how the router is checking its internet connection.
Message 4 of 10
JeffFerg
Guide
Could be but that "something" doesn't block the other manufacturer's Routers in the AP Mode. I will look at that too, thanks.
Message 5 of 10
Guru
could be. if the netgear is "phoning home" to a server on netgear that's blocked, that could be it.
Not sure how exactly it tests its online connection
Message 6 of 10
JeffFerg
Guide
Thanks for all the hints, found the Source of the error. I temporarily disabled the "Intrusion Prevention Service", IPS, on the SonicWALL for the statically assigned IP Address for the the Netgear SRR60-Pro and then the "Red Error" changed to the "Green Good". I then reversed the procedure to keep the IPS Protection active for the downstream devices. The Orbi still works fine.
Thus, the hint of the Orbi "phoning home" could be true, I am still puzzled that the other previously mentioned router makers work fine which to me means that they are not using the same authentication methods.
Thanks again for all the help.
Message 7 of 10
Guru
Message 8 of 10
JeffFerg
Guide
Does clicking on the "Accept as Solution" qualified for "Solved"? If not, please point me to that Button, Thanks.
Message 9 of 10
Guru
yes
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2201 views
  • 3 kudos
  • 2 in conversation
Announcements
