- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR850 rebooting Randomly
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using the Orbi AX6000 Tri-Band Mesh WiFi System (1 RBR850 and 2 RBS850).
Since I purchased the system, it has been rebooting itself at random intervals every couple of days or so. Sometimes a few times a day. After about two weeks, it was getting so bad that I did a complete factory reset and went through the setup process again. Everything was fine for about three weeks, and then it started randomly rebooting again. Last night it rebooted, was on for about 10 minutes, and then rebooted again.
Tech support has been less than helpful and goes through the usual suggestions, firmware check, reboot, wait, and see.
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR850 rebooting Randomly
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried changing the settings. It will take a few days to see if it makes a difference and then which of the settings was causing the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently running firmware 3.2.16.6, ONT is Verizon I-211M-L
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a full power OFF for 1 minute of the ONT and Orbi system been performed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been having this same issue. Been on the phone with Netgear multiple times. This last time they had me change the Routers settings to use Google's DNS...not sure why that would cause a reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@gobblegobble wrote:I've been having this same issue. Been on the phone with Netgear multiple times. This last time they had me change the Routers settings to use Google's DNS...not sure why that would cause a reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
