- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi and EPSON ET-4750 Wireless Printer
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I had a Google Nest Router for several years and just bought the Orbi rourter. Transition has gone mostly smooth. I am having difficulties printing on my EPSON ET-4750 Wireless Printer.
Following the boards, I have done the following:
- CTS/RTS Threshold (1-2347): set to 2347
- Set 2.4ghz channel to 11
- Rebooted Router, Satellite, Cable Modem, Printer
It takes about 20 seconds for my computer to connect to the printer, but when it finally does, it does not successfully print. Any thoughts?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had done the previous steps, then uninstalled my driver, and still could not print.
After more digging, I uninstalled the device (not just driver) and reinstalled both the device and driver. Printing has resumed! Thank you.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi and EPSON ET-4750 Wireless Printer
@hammie1234 wrote:Hi,
I set my CTS/RTS Threshold to 1500
Your 2.4 Ghz will be determined by the traffic you have on different. 11 may be ok, but 1 or 6 may be better.
Re-configure your printer back on the WIFI or check to make sure it is still connected. On your PC, remove and re-install the printer. Then if needed, search for it again. I usually remove the driver as well, but it is not necessary. This final step should resolve the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to check the "RECOMMENDATIONS" seen at the bottom of this thread page as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please mark your thread as solved so others will know.
Enjoy.
