- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection between attached devices drops (no ping possible)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Orbi AC3000 setup with
Hardware Version RBR50
Firmware Version V2.7.5.4
GUI Language Version V1.0.0.423
Operation Mode Router
And three satellites:
RBS50 all on FW V2.7.5.4
Connection on all devices is good.
Issue:
I'm loosing layer 3 network connection between one of my hosts and my wifi network camera.
The effect is somewhat random.
My host is connected with ethernet to one of the satellites.
My wifi cam connect through wifi to a different satellite.
At some point in time, I can't ping the cam from the host anymore.
However I can ping the camera from my laptop.
My laptop is connected with wifi to the RBR50.
Also the internet connection for the wifi cam continues to work fine.
After rebooting the router, the host is able to ping the camera again and connect to it.
I have to reboot my system almost every 1-2 weeks.
I was hoping there is a ways to fix this, or at least force the refresh of the connections without rebooting the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection between attached devices drops (no ping possible)
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the make/model of this WiFi camera?
Does it appear in the list of Attached Devices?
What prompted the desire to ping the camera?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your respose @FURRYe38
>> issue is on local LAN/WIFI only. Internet works fine.
>> 3
>> All RBS show good connection (green)
>> devices right next to an RBS are not reachable too
>> distance is below 30ft
>> not sure, RBSs are always on.
>> yes
>> 2.4GHz Channel:06
5GHz Channel:48
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @CrimpOn
>> Reolink (several models)
>> But I has same issue with Android tablet the other day
>> yes, and the device can be reached from my laptop e.g. which is connected to the router
>> troubleshooting to verify connection
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problems seems to be between RBR and RBS units.
It seems that traffic for certain devices is not forwarded correctly all the time.
I just rebooted on of my cameras and lost connection between my DVR host subsequently.
Before the reboot connection was ok.
CAM is connected via WIFI with RBR (x.y.z.30)
DVR host is connected to RBS Office (x.y.z.98) ping to x.y.z.30 not possible
My laptop is connected to RBR as well (x.y.z.73), ping to x.y.z.30 works!
I will reboot the system now to check if ping between .98 and .30 works again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure enough.
After reboot ping and connection to cam works again.
Is there a way to get more details logs from RBR and RBSs?
Maybe someone from support can look into this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have eight Reolink cameras connected to an Orbi system with one router and three satellites. Did not purchase an NVR host, so cameras are accessed using the Reolink Client software (Windows) or the Reolink Android app.
Does this problem happen with only one camera, or with many?
When the NVR cannot communicate with a camera, but the laptop can, could you temporarily relocate the laptop so that it is connected to the Office satellite. That might help determine if the router to satellite connection is functioning correctly.
Also, the Reolink Client is available for Windows and Mac.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most of us came to the community forum because our 'complimentary' 90 days of support had expired. (mine seven years ago). The only way we can talk to Netgear Support is to purchase a support contract. The problem also must be active and reproducible. If rebooting made eliminated the problem, there is no longer anything to investigate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The issue is not only with my cameras.
My tablet just lost connection to my local server during normal operation.
So tablet can't access anything that is hosted on x.x.x.10.
Will reboot the system another time.
Will also swap out the satellite my x.x.x.10 host is connected to.
Maybe something is wrong with it.
@CrimpOn
>> Intermittent with many
>> I don't know how I can force the laptop to pickup the wifi of the host satellite.
>> I will try next time
>> I know
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't ping my camera again.
Camera is connected to RBR50 via WIFI.
My PC connects to RBS50 via LAN cable.
PC ping to camera does not work.
I was able to connect from my phone to the camera, as long as the phone was also connected through the RBS50. As soon as I moved my phone close to my PC, my phone lost connection as well.
Which strongly indicates that there is something not working correctly between endpoints that are connected via a satellite and other endpoints that connect through the main router.
Firmware is up to date: 2.7.5.4
I would appreciate some help.
Otherwise I need to get rid of my Orbi system and buy something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the model number of this Reolink camera?
(I have a number of Reolink cameras connected to an RBR50/RBS50 system that all work with the Reolink Windows Client and with the Reolink Android app. They respond to ICMP [ping].)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Home Assistant server on my network. Initially, I had it connected via Ethernet to a satellite and it would not be able to communicate with some smart devices (fans, switches, plugs, etc) and could not ping them either.
I now have the server connected via Ethernet to the router. There are less devices that it can’t communicate and all of them appear to be connected to satellites.
I’ve been planning to test without satellites, which I think would solve the issue
- but I would prefer to be able to use them. My house is 3200 sq ft so I suspect we’ll lose WiFi coverage in some parts without the satellites.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
