Orbi WiFi 7 RBE973
Reply
Firmware Orbi RBK50
HoangNa297
Firmware Orbi RBK50
Which firmware is best for Netgear Orbi Rbk50? In 2017, I started using Netgear Orbi rbk50. That is my favourite firmware, but I don't remember that. The latest version( 2.5.1.8 ) the coverage is not extensive; it seems that upgrading NETGEAR makes my router run slower, the throughput is very bad, it's about 200 to 300Mbps. Should I use the custom firmware or downgrade stock firmware?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
CrimpOn
Guru
Re: Firmware Orbi RBK50
You are asking a question that has no easy answer.
  • For many of us, firmware 2.5.1.8 "works great".  No problems.
  • A significant number of people experience a bizzare assortment of issues.  Dropped internet.  Devices missing.  System restarting. Sometimes these issues disappear if the Orbi is "Factory Reset" with 2.5.1.8.  Sometimes people are so frustrated that they manually download and install 2.3.5.30 from summer, 2019.
  • Voxel's custom firmware also "works great" for many people.  I have tried it myself and had zero problems.
So, the number one question is, "Is your Orbi working OK?  Are you having any problems that you want to fix?"  If not, leave it alone and count yourself lucky.  It sounds like you are not happy with 2.5.1.8, so you have two options (1) "go back" to 2.3.5.30  or try Voxel.
This is not a happy situation in "Orbi Land."
Message 2 of 4
HoangNa297
Thank for supporting, I never factory reset it because I think it is working good. In my Netgear orbi app and web I don’t see my ip address, it duplicate my devices ?.. I will try to factory reset it
Message 3 of 4
Guru
Try a factory reset on the RBR and RBS if you haven't tried this after loading v2.5.1.8. If this fails to fix what your seeing, then you can down grade. You can also try Voxels 3rd party FW for Orbi as well:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1839...
Suggestions to try as well:
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2183 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
