- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Orbi RBR50 Dropping Internet Connection Regularly
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 Dropping Internet Connection Regularly
@TonyMcB wrote:
Yes did all the resets and FW updates. Working for everything with the feature on except the older devices. Does not change connection speeds. 1GB up/down connection. Hard wired meets requirements, pulls close to 300MB down on wifi in most locations.
For the benefit of others, what older devices nd how many of each do you have in your home network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So it isn't just the old firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
Does modem have a built in router? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@Alanandstaci wrote:
I am having the same issue, i keep having to reboot about 2 times a day. This is getting old.
- « Previous
- Next »
