- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow Satellite 2 Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get wifi speeds of 4-600 beside router, and beside sat 1.
Beside sat 2 I'm only seeing around 100 sometimes 120 ish.
Is this normal? Should the full speed not carry throughout ?
I noticed moving sat 2 further away helped me with 30 Mbps or so more, even though both location's showed GOOD with 5ghz connections..
Router >sat 1>sat 2
Router FRONT of house against wall basement
Sat 1 BACK of house against wall main floor
Sat 2 BACK of garage (farthest possible from sat 1)
The issue is with speeds at sat 2.
Tech had me change threshold to 2103 on both networks
Daisy chain ,Mimi, fast roaming and beamforcing all ENABLED
On channel 11/40
MTU size 1468.
Any help greatly appreciated
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow Satellite 2 Speeds
Router and sat 1 speeds are fine it's just sat 2.
Would this be something I should try
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Changed MTU back to 1468 fast,mimo,beam all enabled , threshold 2301 .
Sat 2 showing good again 5ghz.. max speeds 100 ish.. 500+ at router and sat 1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.4 transmit power is 25 percent..?? Help please
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between Sat 1 and Sat 2?
Daisy Chain enabled?
What happens if you turn OFF both RBS, swap Sat 1 and Sat 2 locations?
Is the transmit power on the RBR set for 100%?
- Mark as New
- Bookmark
- Subscribe
- Permalink
And it seemed moving sat 2 closer to say 1 gave even worse speeds . It's now farthest in garage just always goes back to 2.4
Daisy chain enabled , fast enabled, 20/40 unticked, mimo enabled beamforcing enabled.
Transmit power is 25 on 2.4 and 100 on 5.
Have tried swapping
- Mark as New
- Bookmark
- Subscribe
- Permalink
Set transmit to 100% on RBR.
Possible that this brick wall will be a factor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. The RBR, ensure both 2.4 and 5G are set for 100%.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible this brick wall is going to be a factor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
5G is effected by building materials. Nature of 5Ghz. It's probably falling back to 2.4G due to the brick wall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
To test this out, place Sat 2 in side the home with sat1 spaced about 25 or 30 feet appart if possible. Check the speed of the Sat 2. I presume Sat2 should hold 5Ghz while in the same building as Sat1 and the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router is front of house basement .
Sat 1 is back of house basement
Sat 2 back of garage ( moving it front of garage speeds were 100 or less when it was working ).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Moving the RBR from basement up to main floor may help some. Basements are not recommended for wifi sources.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
At first it showed good 2.4 then went poor 5g 5 min later..?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get 520mbps sitting on my back patio from sat 1 .. I'm literally 20 ft from sat 2 and I get poor connection..not sure what to do next
