- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS105Ev2 password change crashes in win10 and doesnt change
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cannot change the default, no factory changes have ben made except IP address, have tried even simple passwords, always crashes the config app. Any suggestions would be appreciated. Using utility 2.3.25
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi israelg,
Very appreciate the information that you provided, engineer did see the application crash, please uninstall Plus Utility v2.3.25, and re-install your previous version of Plus Utility (v2.3.24). We will have a fixing release soon.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105Ev2 password change crashes in win10 and doesnt change
Hi israelg,
Welcome to NETGEAR community! To default switch from Utility, are you following below steps?
1> Launch Utility v2.3.25 and select the switch
2> Click "Apply" button and enter right password
3> Select "System->Maintenance->Factory Default", enable checkbox and click "Apply"
4> After that, switch will return to its factory settings
If yes, can you tell us which GS105Ev2 firmware version loading?
"Crash the config app" meaning Utiltiy crash after click "Apply" button? If no, very appreciate if you could clarify more in detail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same thing happens with GS116v2. I removed the application (version 2.3.25) and installed 2.3.20 and it works fine. The switch firmware version is 2.0.1.26.
- Mark as New
- Bookmark
- Subscribe
- Permalink
(oops, make that GS116Ev2). Also Windows 10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi israelg,
