Orbi WiFi 7 RBE973
Reply
GS724T Wall Mount
Frank1101
Follower
GS724T Wall Mount
Hello,
I am trying to find out whether GS724T can be mounted vertically on the wall.
I am looking for a switch that can be closed in a shallow electrical panel with doors (with some, but minimal air flow).
1. Does it have required mounting openings on the bottom?
2. Can it be placed in such position (ports-up)?
3. Will the minimal air flow be a problem if kept below 55C?
Model: GS724T|24-port Gigabit Smart Switch
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: GS724T Wall Mount
@Frank1101,
Welcome to our community! 🙂
I think there are some community members that have tried to mount it vertically but we do have a click switch that can be mounted vertically.
It doesn't have mountings at the bottom of the switch, only on the sides.
Are you planning to wall-mount this?
Definitely, it will just make the fans run at max depending on how many devices will be connected to the switch.
John
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1045 views
  • 0 kudos
  • 2 in conversation
Announcements
