- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
S350 GS348T - VLAN trunk - Switch to Switch not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All
I have connected another switch on to the SFP (Port 47) on this switch and setup tagged VLAN ID on both switch trunk ports (leaving VLAN1 untagged on trunk ports). However, client pcs connected to untagged ports associated with a VLAN propagated to this netgear switch (also adding correct PVID) do not get a network connection (DHCP) - I can see the netgear switch picks up their mac address on the port.
Default VLAN1 traffic works and is propagated (non VLAN) between the switches.
Now if I do the exact setup but connect the router directly on SFP (Port 47) everything works fine so I'm confident my settings are correct on the netgear switch. Is it the upstream switch that's the problem? Should I see the mac address of the router propagated to the netgear switch when it's connected to the other switch?
Any ideas would be greatly appreciated.
Thanks all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: S350 GS348T - VLAN trunk - Switch to Switch not working
All tagged VLANS configured and enabled on both sides of the trunk connection accordingly?
For the access ports to different VLANs - for connecting devices where you expect participation in a VLAN different from the default 1 - are properly configured as untagged for the VLAN, and the PVID is set so the untagged traffic is assigned into the VLAN you expect - and no other VLAN associations?
Is there a DHCP server or service on the other VLAN(s) where you expect clients getting DHCP assignments?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Provide some screenshots from the VLAN and port configurations from both trunk ends.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
