- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Switch configuration for IP Surveillance
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello,
I'm configuring a gs752tpv2 series switch. In my network I have 15 cameras, 1 nvr and 15 pc. I would like to create a PVLAN for the video surveillance network by following this guide:
https://www.netgear.com/images/pdf/IP-Video-Surveillance_Networking-Solution-Guide.pdf.
Sorry my little experience,but I have some questions.The port in promiscous mode has the pvid 100?the nvr is in this port? I have configurated all but it doesn't work and the members on the vlan isolated can communicate each other
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Switch configuration for IP Surveillance
Hi @Retired_Member,
Welcome to the community! 🙂
How is everything connected? On what VLAN does the cameras / PCs / NVR belong?
If ever the cameras are VLAN-aware devices, the ports where the cameras are connected should be set as tagged (T) ports with a PVID corresponding to the VLAN where they belong (for example, if the cameras belong to VLAN 100 connected to ports 1-15, ports 1-15 should be set as tagged ports with a PVID of 100).
The PCs are not-VLAN-aware devices. The ports where the PCs are connected should be set as untagged (U) ports with a PVID corresponding to the VLAN where they belong.
Kindly access and read the article below as reference guide:
What do I need to know about setting up VLANs?
How to create Layer 2 VLANs on NETGEAR ProSAFE Switches
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank you very much for your reply but I wanted to create something safer by following this guide:
but the ports in the isolated vlan are not isolated each other and I wanted to know the VLAN and the pvid of port in promiscuos mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
