Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
4.2.19 Disk Scrubbing with Auto Parity Fix Schedule
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-19
10:26 AM
2011-09-19
10:26 AM
Sceduled the disk scrubbing (Ultra 6) for every 32 weeks on Monday at 14:00h, but it does the scrubbing every week....
Some questions:
- Anybody else have this experience (also with earlier (beta) firmwares)?
- What are the benefits regarding scrubbing? With other words what are the disadvantages when I disable scrubbing?
Thanks in advance.
Some questions:
Thanks in advance.
Message 1 of 14
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-21
08:36 AM
2011-09-21
08:36 AM
Re: 4.2.19 Disk Scrubbing with Auto Parity Fix Schedule
I've noticed mine has switched to doing it every week as well.
Message 2 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-22
06:36 AM
2011-09-22
06:36 AM
same here...
Message 3 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-22
08:56 AM
2011-09-22
08:56 AM
could you guys send in your system log and config backup zip file?
Message 4 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-22
10:18 AM
2011-09-22
10:18 AM
Okay opened a case (#16738656) also because I thought I was the only one.... 😎
Answer from support:
You should look at the disk scrubbing like the disk defregmentation on your local PC. The idea of the scrubbing is to set all the data by special algoritim so it's easier to re-run the data and to allocat it. Regarding the set interval issue, you can try to do a OS re-install on the ReadyNAS. Most likely it's just a OS issue that you're facing. On the following link you can find the instructions on the OS re-install - http://www.readynas.com/kb/faq/boot/how ... _boot_menu
Done the re-install of the OS. Put the settings back with restore and have set the scrubbing for every two weeks. Now let's see what's happening.
Jedi Knight: Thanks for your reply. Will send the files after the test (OS re-install) if there is no improvement. If you can use them now, then please respond and I will be happy to send them.
Regards.
Regards.
Message 5 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-22
12:58 PM
2011-09-22
12:58 PM
Jedi Knight wrote: could you guys send in your system log and config backup zip file?
I'll PM the zip for sure.
If it can help...
Thanks!
Message 6 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-24
12:06 AM
2011-09-24
12:06 AM
I can confirm this problem does exist in 4.2.19. Previously had Disk Scrubbing to run every 2 months which worked without issue. Now it is scheduled weekly as also reported here:
viewtopic.php?f=65&t=57299&p=323388#p323356
My Frontview Settings:
Resultant cron configuration
$ cat frontview-vol_maint
0 3 * * sat root /frontview/bin/vol_maint scrub /dev/c/c
0 4 * * sun root /frontview/bin/vol_maint consistency /dev/c/c
Message 7 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-24
12:37 AM
2011-09-24
12:37 AM
Disk scrubbing on my NAS is now running weekly.
The cron script /etc/cron.d/frontview-vol_maint, I believe is supposed to run weekly.
It executes a script that reads /etc/frontview/vol_maint.conf and should determine from the info in that whether or not to run the check.
As you can see disk scrubbing is scheduled to run every 4 weeks on my unit, and the Online Consistency Check is scheduled to run every week
So I presume the bug is in /frontview/bin/vol_maint or in something that that script uses. I don't believe it's a configuration or GUI problem.
MDGM-NAS:~# cat /etc/frontview/vol_maint.conf
scrub:/dev/c/c:4:XXXXXX
consistency:/dev/c/c:1:XXXXXXX
Message 8 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-28
01:11 PM
2011-09-28
01:11 PM
This problem affects the online file consistency check as well. Happens weekly even though set for lower frequency.
Please fix
Please fix
Message 9 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-30
04:25 PM
2011-09-30
04:25 PM
mdgm wrote: Disk scrubbing on my NAS is now running weekly.
I set up one of my system to scrub every 4 weeks (thursday at 8pm). last night, it triggered the 1st time scrubbing fine . so let see it get trigger again before 4 weeks setup. I can try tweaking the clock to 4 weeks ahead, but I rather leave the system to what you guys are seeing..
Message 10 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-01
10:49 AM
2011-10-01
10:49 AM
bug has been file to developers to take a look. Look like recently changes didn't check the week setting correctly..
Message 11 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-01
04:15 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-04
07:30 AM
2011-10-04
07:30 AM
FYI,
The unit started the scrubbing to early (meaning every week) dispite an OS-reinstall.
Will await the answer of Jedi Knight.
Marcel
Marcel
Message 13 of 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-04
08:26 AM
2011-10-04
08:26 AM
We will get it fix in up coming release. we found the root cause in the script and will get it corrected and fully tested before released..
Thanks for all your concerns and reporting the issues..
Message 14 of 14
