× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Can't connect to admin page (RN104 beta 10 6.2.3)
Nick19007
Can't connect dashboard, only progress bar and "Connecting......"
Message 1 of 16
_J_
Re: Can't connect to admin page (RN104 beta 10 6.2.3)
I had same issue with the new Beta, I am rolling back to 6.2.2. I had the same issue for both 6.2.3 and 6.3.3 beta 10
_J_
Message 2 of 16
mdgm-ntgr
NETGEAR Employee Retired
Do you have SSH access?
If so, so some details from that as to why you are having this problem would be helpful.
If not, I could take a look.
Message 3 of 16
Nick19007
Yes, I have SSH access.
Message 4 of 16
mdgm-ntgr
# systemctl status -a readynasd
# systemctl status -a apache2
# journalctl -a | grep readynasd | tail -n 20
# journalctl -a | grep apache2 | tail -n 20
Message 5 of 16
Nick19007
root@FILESERVERX:~# systemctl status -a readynasd
readynasd.service - ReadyNAS System Daemon
Loaded: loaded (/lib/systemd/system/readynasd.service; enabled)
Active: activating (start) since Wed, 18 Mar 2015 16:40:58 +0400; 8s ago
Main PID: 12028 (readynasd)
Status: "Importing DB"
CGroup: name=systemd:/system/readynasd.service
└ 12028 /usr/sbin/readynasd -v 3 -t
Mar 18 16:40:58 FILESERVERX readynasd[12028]: readynasd log started
Mar 18 16:40:58 FILESERVERX readynasd[12028]: readynasd started. (restarted=0)
Mar 18 16:40:58 FILESERVERX readynasd[12028]: DB (main) schema version: 17 ==> 17
Mar 18 16:40:58 FILESERVERX readynasd[12028]: DB (queue) schema version: new ==> 0
root@FILESERVERX:~# systemctl status -a apache2
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled)
Active: active (running) since Wed, 18 Mar 2015 12:45:24 +0400; 3h 59min ago
Process: 1682 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=0/SUCCESS)
Process: 1151 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)
Main PID: 1706 (apache2)
CGroup: name=systemd:/system/apache2.service
├ 1706 /usr/sbin/apache2 -k start
├ 1707 apache_log
├ 1769 /usr/sbin/apache2 -k start
├ 1771 /usr/sbin/apache2 -k start
├ 1772 /usr/sbin/apache2 -k start
├ 1774 /usr/sbin/apache2 -k start
├ 3035 /usr/sbin/apache2 -k start
├ 4298 /usr/sbin/apache2 -k start
├ 4322 /usr/sbin/apache2 -k start
├ 4331 /usr/sbin/apache2 -k start
├ 4332 /usr/sbin/apache2 -k start
├ 6066 /usr/sbin/apache2 -k start
└ 6165 /usr/sbin/apache2 -k start
Mar 18 12:58:11 FILESERVERX apache_access[1707]: 192.168.1.34 "POST /fsbroker/ HTTP/1.1" 200
Mar 18 12:58:11 FILESERVERX apache2[6066]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[6066]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache_access[1707]: 192.168.1.34 "POST /dbbroker HTTP/1.1" 500
Mar 18 12:58:11 FILESERVERX apache_access[1707]: 192.168.1.34 "POST /fwbroker HTTP/1.1" 200
Mar 18 12:58:11 FILESERVERX apache2[1772]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[1772]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[6165]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[6165]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
root@FILESERVERX:~#
root@FILESERVERX:~# journalctl -a | grep readynasd | tail -n 20
Mar 18 16:45:51 FILESERVERX readynasd[13541]: dba import failed
Mar 18 16:45:51 FILESERVERX systemd[1]: readynasd.service: main process exited, code=exited, status=255
Mar 18 16:45:51 FILESERVERX systemd[1]: Unit readynasd.service entered failed state.
Mar 18 16:45:51 FILESERVERX systemd[1]: readynasd.service holdoff time over, scheduling restart.
Mar 18 16:45:51 FILESERVERX readynasd[13616]: readynasd log started
Mar 18 16:45:51 FILESERVERX readynasd[13616]: readynasd started. (restarted=0)
Mar 18 16:45:51 FILESERVERX readynasd[13616]: DB (main) schema version: 17 ==> 17
Mar 18 16:45:51 FILESERVERX readynasd[13616]: DB (queue) schema version: new ==> 0
Mar 18 16:46:05 FILESERVERX readynasd[13616]: Unknown driver nutdrv_atcl_usb
Mar 18 16:46:05 FILESERVERX readynasd[13616]: rndb_ups_import() ==> 1 (3ms)
Mar 18 16:46:05 FILESERVERX readynasd[13616]: rndb_import() ==> 1 (14026ms)
Mar 18 16:46:05 FILESERVERX readynasd[13616]: Error rndb_import() ==> rc=1
Mar 18 16:46:05 FILESERVERX readynasd[13616]: dba import failed
Mar 18 16:46:05 FILESERVERX systemd[1]: readynasd.service: main process exited, code=exited, status=255
Mar 18 16:46:05 FILESERVERX systemd[1]: Unit readynasd.service entered failed state.
Mar 18 16:46:05 FILESERVERX systemd[1]: readynasd.service holdoff time over, scheduling restart.
Mar 18 16:46:05 FILESERVERX readynasd[13690]: readynasd log started
Mar 18 16:46:05 FILESERVERX readynasd[13690]: readynasd started. (restarted=0)
Mar 18 16:46:05 FILESERVERX readynasd[13690]: DB (main) schema version: 17 ==> 17
Mar 18 16:46:05 FILESERVERX readynasd[13690]: DB (queue) schema version: new ==> 0
root@FILESERVERX:~#
root@FILESERVERX:~# journalctl -a | grep apache2 | tail -n 20
Mar 18 12:58:11 FILESERVERX apache2[4331]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[4331]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[1773]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[1773]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[1771]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[1771]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[4332]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[4332]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[4322]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[4322]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[4298]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[4298]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[3035]: [error] [client 192.168.1.34] Connect rddclient failed, referer: https://192.168.1.37/admin/
Mar 18 12:58:11 FILESERVERX apache2[3035]: [error] [client 192.168.1.34] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.37/admin/
root@FILESERVERX:~#
Message 6 of 16
mdgm-ntgr
There is a fix for this problem coming in the next 6.2.3 build.
Message 7 of 16
Nick19007
Watch out for firmware updates and install beta 11 ?
Message 8 of 16
mdgm-ntgr
Yes.
Message 9 of 16
Nick19007
Many thanks, will report how will the update.
Message 10 of 16
mdgm-ntgr
In the meantime you may wish to disconnect the USB cable from the UPS temporarily and enter these commands:
# echo > /etc/nut/ups.conf
# systemctl restart readynasd
Message 11 of 16
A2D2RAS
I don't have SSH to mine, not sure what to do.
I can ftp and connect using windows explorer but I cannot access the web interface page.
Message 12 of 16
Guru
You can contact support.  If you were affected by the 6.2.2 uninstall bug they should fix it for free.  Otherwise they will charge.
If you want to avoid contacting support, you can back up your data to an external drive.
From there you can do a factory reset, and restore your data from backup.  There is also a trick you can try if you have a scratch disk handy, but you should make the backup first.
Message 13 of 16
A2D2RAS
I have 4 hard drives in there, can I just take them out reset the NAS then put the 4 hard drives back in?
Mine is a RN31400, not sure what version firmware it is running..
Message 14 of 16
Guru
You can reset the NAS with the drives in, but you will lose all the data.
The OS is on the disks, so it is impossible to reset the NAS with the drives out.
RAIDar should be able to tell you the firmware version.
Message 15 of 16
A2D2RAS
Installed the app and it is in fact 6.2.2
Thank you so much StephenB
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 8229 views
  • 1 kudo
  • 5 in conversation
Announcements
