× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
XBOX 360 and ReadyNAS Ultra 4
claytonb
Is there a problem with the beta firmware versions seeing the ReadyNAS from the XBOX?
If someone can confirm this, I'll stop searching for a fix.
Message 1 of 8
OneFast440
Re: XBOX 360 and ReadyNAS Ultra 4
I am having the same issue... No fix as of yet.
Message 2 of 8
signalman
I have had this problem on my duo v1 since an upgrade (and subsequent downgrade) to/from T6 beta
Everything else works fine
Message 3 of 8
Skywalker
NETGEAR Expert
I just posted a new addon in the ReadyDLNA addon thread that should fix this issue. Let me know if you still have problems after updating to version 1.0.24.3.
Message 4 of 8
OneFast440
Thank you! My Xbox360 can now see my ReadyNAS!!!!
Message 5 of 8
signalman
Hi Skywalker
Reset router, updated to T6 (again), Installed 1.0.24.3 and everything worked fine again straight away
Thank you very much for providing the update
It did have one advantage of being temporarily broken ... I learn't a lot about networking
Thanks again
Message 6 of 8
OneFast440
Is it a bug if now when multiple folders are selected in ReadyDNLA they all show up in just one big folder on the 360? I have noticed this in earlier versions as well but at one time it would keep them separate.
Message 7 of 8
claytonb
Thanks, everything is working now
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 5123 views
  • 0 kudos
  • 4 in conversation
Announcements
