- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readnas cannot connect to readycloud
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear engineers connected to my NAS via ReadNAS Diagnostic mode and removed a corrupt Config file. Once they removed the config file, I was able to connect to ReadyCLOUD. Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readnas cannot connect to readycloud
I am facing exact same issue - message says "Something is preventing the ReadyNAs from.....".
I am unable to access it from outside my home network. I appreciate if Netgear can hep me with the diagnostic and fix.
Kind regards,
Vinay Verma
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Appiero,
I am having this problem as well and by any chance do you know the location of this config file that the engineers renamed/removed?
I have 3 ReadyNAS servers running and only one of them is not connecting to ReadyCloud; I am receiving messages that ReadyNAS Replicate will be decommissioning and I do not want to be left with this NAS (my primary) not being setup properly.
Cheers,
Rick
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS Replicate setup that i need to replicate with ReadyCloud
- Mark as New
- Bookmark
- Subscribe
- Permalink
That would be great. This can be a simple fix if we just know the procedure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @rickr1
I would advise contacting NETGEAR Support and create a case, they can assist you with your ReadyNAS units.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Creating a case with ReadyNAS - will it be a chargable activity? Mine is out of warranty.
Kind regards,
Vinay Verma
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:
If your NAS was purchased between June 1, 2014 and May 31, 2016 then lifetime Chat Support is available.
This doesn't apply to the RN100 or RN200 platforms, it is limited to the "business" OS 6 ReadyNas (Rackmount, RN300 series and above).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately, mine is 2013. Can ReadyNAS mention steps to fix here which we can apply ourselves?
It doesn't seem genuine that a patch from Netgear created this issue and we are forced to pay for support to get it fixed.
Ideally it should be treated as defect and Netgear should issue a patch to fix it automatically.
Kind regards,
Vinay Verma
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is your NAS connecting to the internet generally? For instance, did you recently see the update notification for 6.9.2?
Also, what firmware are you running?
Are you seeing the green internet check box on the cloud page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi StephenB,
Yes, my ReadyNAS is conected to internet - I am seeing green internet check box.
I am also recieveing upgrade notifications. Recently I upgraded to 6.9.2.
Kind regards,
Vinay Verma
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:
hopefully @StephenB can reach out to you as well. I believe he's working with @vverma01 to get his resolved.
As far as ReadyCloud goes, I focus on whether the NAS has the right network connection to reach the internet. I can't really go further than that - I access my own NAS remotely using VPN, not ReadyCloud. So once it's clear that the issue isn't the network itself, I need to leave it to the Netgear team.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Marc_V,
I purchased the one i am having issues with 2nd hand and I do not have access to the original purchase receipt, so I would need to pay for the service call. But honestly this is just so wrong, you should provide OS upgrades for the purposes if fixing bugs and not to generate paid service requests. I just hope that it is not too expensive.
I am quite disapponted with that fact, but I need to be able to access these devices when I am away from home.
RIck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Stephen. My NASes all have full network access to the Internet and are all configured in exectly the same way with the exception of this problem of it not being able to register with readycloud.
Actually, I may turn this around and provided I can swap my drives around between the NASes maybe I acn demote this one to a backup role and promote one of my other ones to be the primary role. But realistiacally I should not be having this problem at all. The ALL my NASes are running at the same OS releases and I upgrade all of them at the same time.
Netgear should publish more information on this issue if they cannot automate a patch.
Cheers,
Rick
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you send in your logs (see the Sending Logs link in my sig)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear's policy is that they won't provide paid support for used ReadyNAS (even if you are willing to pay). So you are dependent on this forum.
You could try swapping disks with one of your new NAS, and if the problem moves with the disks you would be able to use paid support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@rickr1 you may not have to pay or play around with swapping disks. I was out of support as well and a Netgear Engineer picked the issue up from this community, remoted in to my NAS and deleted the corrupt file. It was very simple, took less than 5 minutes and was very impressive. This is an issue that affects many users and it seems the resolution requires deleting this corrupt file.
Can a Netgear Engineer reach out to Rick?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mdgm-ntgr already has.
My take was that Rick wasn't intending to use paid support for this; my info on paid support policies was really for future reference.
FWIW, personally I don't use ReadyCloud at all (I prefer OpenVPN and ZeroTier for remote access). If I did use it, I'd only enable it for one NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can Netgear support atleast publish the details the file to be deleted. It will help users to make full use of ReadyNAS.
Else Iin absence of support, I am thinking of one time investment to migrate to Netgear competitor.
Kind regards,
Vinay Verma
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you provide me logs from your system that can't connect to ReadyCLOUD. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This thread is a bit tangled (Rick and Vinay are currently sharing it). Do you want logs from Rick or Vinay or both?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi StephenB and mdgm,
I just mailed logs for mdgm's attention.
Kind regards,
Vinay Verma
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it is a problem with the config file as it appears to be in vverma01's case there are a few options:
The first is:
1. Backup your data
2. Verify your backup is good
3. Do a factory default (wipes all data, settings, everything)
4. Restore your data from backup and manually reconfigure the NAS
Or I can discuss an alternative option via PM.
