Orbi WiFi 7 RBE973
Reply
readycloud doesn't seem to work right in samsung nugat 7.0
techman05
Guide
I can't tap on my nas to view my files but I can connect. Any idea if theres a version compatible with android 7.0 coming out soon that should work with it?
Thanks
Message 1 of 5
FramerV
NETGEAR Employee Retired
Re: readycloud doesn't seem to work right in samsung nugat 7.0
Hi techman05,
We have no updates yet about the upcoming release. Hopefully some of the dev team updates us.
Message 2 of 5
BingkeX
NETGEAR Expert
Hi techman05,
I don't have samsung nugat 7.0 device, but i have LG Nexus 5X with Android 7.0 version. And with Android app 1.2.11 version, i can access files on nas successfully in same LAN.
Which readycloud android app version do you use?  And you use 3G/4G to access files on nas or WIFI?
Message 3 of 5
techman05
Guide
same version but nothing going. It bow just says a device name and when I pull down says disconnected and thats after I re-login.
Was there anything I was supposed to tweak after 6.5 to keep everything running smooth? I am a my.netgear for both this account and my device account.
Message 4 of 5
FramerV
Hi techman05,
Are you still running 6.5.0 on your ReadyNAS? An update to the latest firmware on the ReadyNAS might help.
Lets wait for other in the community if someone has experience with a Samsung device.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3105 views
  • 0 kudos
  • 3 in conversation
Announcements
