jiska78's avatar
jiska78
Tutor
Aug 02, 2016
Problems installing Python
Something is very stuffed in my NAS. I'm trying to install Python and I'm getting all sorts of problems.
I've been googling for days and tried a hundred different ideas but nothing seems to be working.
Is anyone able to help?
root@NAS01:~# apt-get install python
Reading package lists... Done
Building dependency tree
Reading state information... Done
python is already the newest version.
python set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
8 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up python2.7-minimal (2.7.3-6+deb7u3) ...
Linking and byte-compiling packages for runtime python2.7...
Traceback (most recent call last):
  File "/usr/bin/pycompile", line 35, in <module>
    from debpython.version import SUPPORTED, debsorted, vrepr, \
ImportError: No module named debpython.version
dpkg: error processing python2.7-minimal (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of python-minimal:
 python-minimal depends on python2.7-minimal (>= 2.7.3-1~); however:
  Package python2.7-minimal is not configured yet.
dpkg: error processing python-minimal (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python2.7:
 python2.7 depends on python2.7-minimal (= 2.7.3-6+deb7u3); however:
dpkg: error processing python2.7 (--configure):
dpkg: dependency problems prevent configuration of python:
 python depends on python2.7 (>= 2.7.3-1~); however:
  Package python2.7 is not configured yet.
 python depends on python-minimal (= 2.7.3-4+deb7u1); however:
  Package python-minimal is not configured yet.
dpkg: error processing python (--configure):
dpkg: dependency problems prevent configuration of python-cheetah:
 python-cheetah depends on python2.7; however:
 python-cheetah depends on python (>= 2.6.6-7~); however:
  Package python is not configured yet.
 python-cheetah depends on python (<< 2.8); however:
dpkg: error processing python-cheetah (--configure):
dpkg: dependency problems prevent configuration of python-configobj:
 python-configobj depends on python2.7 | python2.6; however:
  Package python2.6 is not installed.
 python-configobj depends on python (>= 2.6.6-7~); however:
 python-configobj depends on python (<< 2.8); however:
dpkg: error processing python-configobj (--configure):
dpkg: dependency problems prevent configuration of python-feedparser:
 python-feedparser depends on python2.7 | python2.6; however:
 python-feedparser depends on python (>= 2.6.6-7~); however:
 python-feedparser depends on python (<< 2.8); however:
dpkg: error processing python-feedparser (--configure):
dpkg: dependency problems prevent configuration of python-pkg-resources:
 python-pkg-resources depends on python (>= 2.6); however:
 python-pkg-resources depends on python (<< 2.8); however:
dpkg: error processing python-pkg-resources (--configure):
Errors were encountered while processing:
 python2.7-minimal
 python-minimal
 python2.7
 python
 python-cheetah
 python-configobj
 python-feedparser
E: Sub-process /usr/bin/dpkg returned an error code (1)
If I try and install python-minimal and it gives this:
root@NAS01:~# apt-get install python-minimal
python-minimal is already the newest version.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello jiska78,
    What's the model and FW version of your NAS? Did you try installing through the admin page > Apps > Available apps if you have a ReadyNAS OS6?
    • jiska78's avatar
      jiska78
      Tutor
      Hi Jen,
      Thanks for your reply, but none of those things are really relevant. The problem exists at shell level and has nothing to do with the webservices gui that Netgear have installed on the box.
      However, I have a ReadyNAS314, on firmware version 6.5.1 and yes I have tried installing via the GUI, which as far as I know simply executes the apt-get command on the backend, and it fails.
      • JennC's avatar
        JennC
        Hello jiska78,
        I see, then I think it is best if you contact support center about this.
        I checked your profile and found that you are a PowerShift member, please contact support center to report this so it can be escalated to higher tier.
ProSupport for Business
