Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SABnzbd++
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-05
02:12 PM
2010-11-05
02:12 PM
Re: SABnzbd++
WhoCares? wrote: Manually installed?
-Stefan
If by manually you mean first installing Python then the Sabnzbd bin from the ReadyNas Pro admin web page then yes.
Message 26 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-05
02:38 PM
2010-11-05
02:38 PM
Re: SABnzbd++
No, I meant whether you tried to install Python and SABnzbd on your own. Anyway, this behavior seems to be caused by a bug in OpenSSL as you can read here.
Unfortunately there isn't much I can do about this other than installing a replacement openssl library with SABnzbd/Python. Since openssl is a crucial part of the system I'm quite reluctant to do so but rather would think a fix (if any is deemed necessary) has to come by way of a firmware update from Netgear. Now I'm fully aware that fixing problems with a third party add-on probably isn't on top of the todo list so my best advice for now is to restart SABnzbd frequently. I could also add a cron job to do just that to future releases if that would be ok as a workaround.
-Stefan
-Stefan
Message 27 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-06
03:05 AM
2010-11-06
03:05 AM
Re: SABnzbd++
WhoCares? wrote: No, I meant whether you tried to install Python and SABnzbd on your own. Anyway, this behavior seems to be caused by a bug in OpenSSL as you can read here.
-Stefan
Too bad. I kinda liked the idea of running all my downloads straight from the NAS.
Anyway, I will go back to running it from my HTPC and wait for another more stable version.
Thanks for your support.
Message 28 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-08
08:30 AM
2010-11-08
08:30 AM
Re: SABnzbd++
-Stefan
You know, when I reverted back to the HTPC i also had some weird behavior involving SSL. It disappeared only after i deleted all my old Sabnzbd certificates from IE8 and Firefox.
I am wondering if.....
P.S: What about the new issue of SabNzbd v.0.5.5?
Message 29 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-08
08:51 AM
2010-11-08
08:51 AM
Re: SABnzbd++
Well, you know, a day has just 24 hours and even if I'd add the night ... in short: when time permits 😉
-Stefan
-Stefan
Message 30 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-08
10:04 AM
2010-11-08
10:04 AM
Re: SABnzbd++
WhoCares? wrote: Well, you know, a day has just 24 hours and even if I'd add the night ... in short: when time permits 😉
-Stefan
Of course. But what do you think about SSL?
Maybe I should try again and this time i will clean up certificates.
But before I go through all the procedure, do you think that a bad certificate on a browser accessing the NAS could crash the Sabnzbd daemon on the NAS?
Message 31 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-08
01:12 PM
2010-11-08
01:12 PM
Re: SABnzbd++
xtrips wrote: But before I go through all the procedure, do you think that a bad certificate on a browser accessing the NAS could crash the Sabnzbd daemon on the NAS?
Maybe, yes. The problem with this SSL bug - as far as I understand it - is that the SSL library is either receiving too much certificates or one that exceeds the expected length. A broken certificate may well fall into the latter category.
-Stefan
Message 32 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-08
01:47 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-08
02:19 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-15
08:32 AM
2011-09-15
08:32 AM
Re: SABnzbd++
Is it possible to change the base folder?
I would like to place the complete download folder and the detect folder somewhere else. not in /c/.sabnzbd
Message 35 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
05:03 AM
2011-09-18
05:03 AM
SABnzbd++
Basically you can place it anywhere you like. Just make sure that you get all the ownership and permission stuff right. And maybe watch out to locate it somewhere below the /c directory since otherwise you'll end up with a full OS partition.
-Stefan
-Stefan
Message 36 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
09:34 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
10:07 AM
2011-09-18
10:07 AM
Re: SABnzbd++
Sure. You go to SABs config screen, click on the Folders section and change whatever folder you want to change.
-Stefan
-Stefan
Message 38 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
10:25 AM
2011-09-18
10:25 AM
Re: SABnzbd++
You can't change it to anything you like cause it says there is a base folder: /c/.sabnzbd and you can only create of select folder in there.
I use the sabnzbd add on
Message 39 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
10:54 AM
2011-09-18
10:54 AM
Re: SABnzbd++
just type the path you want to use
ie
/c/downloads/incomplete
/c/downloads/completed
/c/downloads/watched
ie
NOTE: Folders will be created automatically when Saving. You may use absolute paths to save outside of the default folders.
Message 40 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
10:58 AM
2011-09-18
10:58 AM
Re: SABnzbd++
I don't see this message: NOTE: Folders will be created automatically when Saving. You may use absolute paths to save outside of the default folders.
I want to change it to another share
/c/data/downloads
How can i do that?
/c/data/downloads
How can i do that?
Message 41 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
11:09 AM
2011-09-18
11:09 AM
Re: SABnzbd++
Also what is the max download speed of the readynas? on my PC with SABnzbd i get 14MBps on the readynas only about 8
Message 42 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
11:22 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
11:28 AM
2011-09-18
11:28 AM
Re: SABnzbd++
if I type this in /c/data/downloads it wiill create a new directory /c/.sabnzbd/c/data/downloads
I have a Ultra 2
Where can i find the global speed limit?
I have a Ultra 2
Message 44 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
11:38 AM
2011-09-18
11:38 AM
Re: SABnzbd++
Your nzbbd look completly diff and the base folder doesn't count for you download folder
Message 45 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
11:39 AM
2011-09-18
11:39 AM
Re: SABnzbd++
GBE88 wrote: if I type this in /c/data/downloads it wiill create a new directory /c/.sabnzbd/c/data/downloads
it works in the version I have, see screenshot above, have you actually tried?
my version is several releases old (v0.5.6-rnx86-0.2.1), so maybe its changed in later versions.
I have a Ultra 2
should be fine
well unless the UI has changed or is otherwise different from my screenshot, there should be a pretty obvious text box that says speed limit. If its blank then there is no limit set, so the problem is elsewhere. Otherwise I suggest you start looking at all the config/option screens.
Message 46 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
11:44 AM
2011-09-18
11:44 AM
Re: SABnzbd++
look, if typing in the full path (/c/data/downloads) does not work for you, then you may have to use ssh and login and create a symlink from the sabnzbd folder to the downloads folder you want.
http://linux.byexamples.com/archives/19 ... e-symlink/
Message 47 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-18
02:08 PM
2011-09-18
02:08 PM
Re: SABnzbd++
Sabnzbd writes downloaden file as admin user. Is there a way to change this? I allready set read/write permissions on that share for my account but still can't delete folders that sab creates
Message 48 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-19
11:24 AM
2011-09-19
11:24 AM
Re: SABnzbd++
I bought the newest version, can i also download older version for free now?
Message 49 of 51
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-20
02:29 PM
2011-09-20
02:29 PM
Re: SABnzbd++
When i download a file with sabnzbd on readynas i get 4MBps, when i download the same file on my windows machine with sabnzbd i get 11MBps. I have a Ultra 2.
When i copy files on the network i het write speeds of 50/60 MBps.
I have no speedlimit set in sabnzbd. Why is it so slow?
Message 50 of 51
