× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
How to login backend to a ReadyMas Ultra 2.
Ylle
Tutor
I have two ReadyNas Ultra 2. They work fine, but since all webb browsers now are upgraded to not accept certificate errors any more none of them won´t let me in tp the admin area with all the settings.
I would be very happy if there is a workaround to solve my problem.
Message 1 of 16
Accepted Solutions
Guru
Re: How to login backend to a ReadyMas Ultra 2.
Have you tried forcibly powering down and then rebooting the NAS?
Message 8 of 16
All Replies
Guru
FWIW, the problem isn't the certificates.  It's about TLS 1.0.  New browsers are dropping that (requiring TLS 1.2).
You can still connect with internet explorer (or edge in IE mode).  If that's not an option for you, you can download an old version of FireFox - 94.0.2 will work.  Make sure you immediately update the settings to turn off auto-update.
Once in, you can install this add-on from @WhoCares_ (www.rnxtras.com😞 https://github.com/rdynsxtrs/rn4bin/blob/main/apache2/x86/Apache2_2.2.34-x86-0.2.0.bin That will add support for TLS 1.2 to your NAS.
Longer term, you might consider converting your NAS to run OS 6 firmware.
There is a much longer thread on this issue here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER...
Message 2 of 16
Ylle
Tutor
OK, got that.
Yes, Works fine. Thank you so much!
This is a good idea. I wish I could understand how to install the add-on. I tried to just paste the link https//github... but the Nas rejected. I would appreciate more detailed instructions.
Yes, could be the next step.
Message 3 of 16
Sandshark
Sensei
You have to download the file to a PC, then use the NAS menu to install the add-on from a local source.
Message 4 of 16
Ylle
Tutor
Finally I found the download button and the Nas accepted the file as possible to install. Unfortunately I got tyis error message:
"The Apache2 add-on encountered an error during installation."
Message 5 of 16
Guru
Try testing it with your usual browser, and see if it works (despite the error)
Message 6 of 16
Ylle
Tutor
I am sorry to say. It does not work to access with Edge and not with Firefox 94.0.2 as well
I have two subnets, 192.168.1.101 and 192.168.2.1
  • My computer is connected to 192.168.2.1
  • I can access the admin page at Nas 192.168.1.101
  • I can not access the admin page at Nas 192.168.2.101 (caused by the add-on?)
  • My Nas 192.168.2.101.is visible in Raidar
  • I can access the files in both Nas (that has never been a problem)
I enclose screen shots.
Message 7 of 16
Guru
Message 8 of 16
Ylle
Tutor
I did so an now it works fine, even with Egde. When I am present at the same location I will do the same with 192.168.1.101.
Apeche came into opertion when I rebooted the Nas.
Thanks!
I am receiving plenty of error messages regarding low voltage. Are there any support articles about that. Otherwise i may issue a new ticket.
The same about OS6. Any articles about that.
Message 9 of 16
Guru
One of several posts on that is here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/upgrade-for-my-Ultra-2-Plus/td-p/2160134
The upgrade process is the same for the Ultra 2 and the Ultra 2 plus, but I think the two chassis take different memory.
You could try getting a replacement power adapter
Message 10 of 16
Sandshark
Sensei
The Ultra2, Ultra2Plus, and Pro2 differ only in what processor is on the board.  They use the same RAM  The Ultra has a single core processor and the other two have a dual core.  The same is true of the Ultra4/Ultra4Plus/Pro4 (but different processors and RAM from the 2-bay units).
Message 11 of 16
Ylle
Tutor
OK, so far so good. Now there is a syncronising process i progress. I seems to be very slow 1%/hour. That makes above four days.I don´t know if it is possible to shut down the computer. Anytway, lucky for me I don´t need to move the laptop anywhere else so I just let it be connected.
Message 12 of 16
Guru
You can shut down the laptop, just keep the NAS running.
Sync time depends on the disks you are using - can you let us know the manufacturer and model?
Message 13 of 16
Ylle
Tutor
Finally the sync is finished.
Seagate or WD 2 TB. (maybe bought 2011)
I tried to sign in to the Nas,  with Edge and Firefox. Not possible in any case.
Message 14 of 16
Guru
The user name is admin, the default admin password for OS-6 is password.  Are you saying those credentials don't work?
Message 15 of 16
Ylle
Tutor
Ahh... Just the wrong password.
I have performed the setup and also uppdated firmvare. Everything works fine.
Thank you very much for help!
Message 16 of 16
Discussion stats
  • 15 replies
  • 3230 views
  • 2 kudos
  • 3 in conversation
Announcements
