Papagaiou
Oct 05, 2012Aspirant
phpMyAdmin complains about mcrypt not being installed
Hello,
I noticed that phpMyAdmin (from WhoCares) complains that mcrypt is missing (from PHP addon of WHocares)
I cannot fixed with apt-get because the dependency are not the same.
Also what is the admin login? I tried root admin with my passwor without success? and id do not see the " New: Access level configuration from within Frontview "
How should that be fixed?
Thank you.
Thank you.
- mdgm-ntgrNETGEAR Employee RetiredWhat model ReadyNAS is this?
What version of the PHP add-on?
What version of the PHPMyAdmin add-on?
Have you checked to make sure the mcrypt module is enabled in the PHP add-on configuration (e.g. in Frontview under Add-ons > Installed > PHP5 if this is on your Ultra)? If it's not enabled it, enable it (don't forget to click Apply). - PapagaiouAspirantWhat model ReadyNAS is this?
Ultra 2 running 4.2.22
PHP5_5.3.14-rnx86-4.2.1
PRO-PHPMyAdmin_2.5
Yes it is enabled. - mdgm-ntgrNETGEAR Employee RetiredSounds like your PHP add-on is out of date. Can you try the latest version of the add-on?
- PapagaiouAspirantactually i messed up between php from Whocares and SuperPoussin MyphpAdmin.
I updated php and unstalled PromyphpAdmin then installed Myadmin from whocares.
The problem is that I do not see the Use and Configure buttons in the Addon and I still cannot login because I do not know the default Admin password. Help please ! - mdgm-ntgrNETGEAR Employee RetiredTry clearing your web browser cache (e.g. Temporary Internet Files in IE), close your web browser then reopen Frontview.
- PapagaiouAspirantOk after some mysql lines I manage to connect as root. and a clear cache indeed resolve the button issue.
Everything seems to works. I just have a complain of phpmyadmin which said that the phpMyAdmin configuration storage is not complete.
