- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RR3312 Compatible with EVO 860 mz-76p1t0bw?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm looking at getting a diskless enclosure and buying the new EVO 860 SSD's for it. My only reservation is that they aren't on the compatibility list, although the older 850 PRO MZ-7KE1T0BW is on the compatibility list. Any reason to think that the 860's wouldn't work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RR3312 Compatible with EVO 860 mz-76p1t0bw?
Hi @ComputerCPR
Welcome to the Community!
The EVO 860 if right has the same interface SATA 6GB/s so it should be working fine with the RR3312. Given that the 850 Pro is listed we can say the same would go with the 860.
To say, the HCL has not been fully updated or not being updated in a regular interval since doing tests on different disks models and brands do take time but most of the disks coming out today are always compatible with the ReadyNAS systems.
Hope this helps!
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, but do pay attention to the "endurance" specification (TBW, or "terabytes written"). Generally that spec is higher for larger capacity SSDs.
If you use flexraid, you could get a larger SSD, but create a smaller RAID group that doesn't use the full capacity. That is a form of "overprovisioning" that should give you a longer drive life (since scrubs and resyncs only apply to the RAID partition).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @ComputerCPR
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
