× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 2120 v2 Missing Volume after reboot
aldawson
Recently upgraded to 6.9.3.
2120 with 4x4TB drives
Now after a reboot - NAS advises that no volume exists when I navigate to view the iscsi LUNS, which is all we really use.
we did have a \data volume with 2GB free!
all other configuration is present and correct - even the LUNS are listed
NAS is only used as vmware datastore location, backups were made to faclilitate file level recovery using veamm - to another iscsi lun on same NAS (which is also inaccessible)
any guidance would be appreciated
Model: RN21244E|ReadyNAS 2120 1U 4- Bay 4x4TB Enterprise Drive
Message 1 of 6
JohnCM_S
NETGEAR Employee Retired
Re: ReadyNAS 2120 v2 Missing Volume after reboot
Hi aldawson,
Welcome to the Community!
Can you download the NAS system logs? If you can, you may provide it to us. You may check this link for the procedure on how you can send it.
Message 2 of 6
aldawson
Hi JohnCM_S
logs have been emailed over to nsbu_logs
Regards
Al
Message 3 of 6
JohnCM_S
Hi aldawson,
Thank you for providing the logs. The logs are actually flooded with messages about iSCSI. It could be that there is a file system issue but we are not yet sure what it is. Can you boot the NAS into Volume Read-only mode and then download the logs ASAP after it comes up?
Message 4 of 6
mdgm-ntgr
Some would say that backups stored on the same device are not much of a backup as there's a single point of failure.
The logs suggest that it failed to recover balance.
Apr 18 09:42:40 NAS kernel: BTRFS error (device md127): bad tree block start 13045144509306137155 19182968307712
Apr 18 09:42:40 NAS kernel: BTRFS error (device md127): failed to recover balance: -5
Apr 18 09:42:40 NAS kernel: BTRFS error (device md127): open_ctree failed
Were you running a balance on this when the problem happened? How did you run that balance?
Message 5 of 6
aldawson
Hi
"Were you running a balance on this when the problem happened? How did you run that balance?"
No - balance wasn't being run, wouldn't know how to do that.
issue was identified after users were not able to connect to shared files located via a windows server iscsi connection on the NAS.
The NAS was ultimately rebooted via the web gui, i did notice that the \data volume was present before the reboot but missing after
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1165 views
  • 0 kudos
  • 3 in conversation
Announcements
