Tetsugaku
Nov 03, 2015Follower
Wired router with POE and Gigabit ethernet to run two Linksys AC1750 access points?
Hello, I'm looking for a recommendation for a wired Router with POE and Gigabit ethernet to connect to two LinkSys AC1750 ceiling access points routing internet on the WAN socket from a british Virgin Media cable connection - can anyone advise a good solution?
I'm a home office / small office user so there's several wired devices going in and a mix of wireless clients. I need at least 8 ethernet sockets. SPeed performance and reliablity are important, but not important enough to go overboard on cost!
Huge thanks to you all.
1 Reply
- JohnRoNETGEAR Employee Retired
Hi Tetsugaku,
Welcome to the community!
As of the moment we do not have a router with PoE functionality, what I can recommend are two units. You can get an FVS318G, it's a non-wireless firewall router with 8-gigabit ports, VPN and high security (this will connect to your Virgin Media cable connection and distribute it to your devices). For the switch, I would like to recommend the GS110TP. The GS110TP is an 8-port all PoE gigabit switch with additional 2 SFP ports, this is very small and has a metal casing.
If you have more questions, the community is happy to help!
Thanks,
