× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How to Disable remote login
008MB
I can't seem to disable remote login to admin.  i.e.  using my phone with wifi on I can login to admin via 192.168.1.1    shouldn't i be able to disable this access?
Mike
Model: R6230|AC1200 Smart WiFi Router Dual Band Gigabit
Message 1 of 5
Accepted Solutions
Guru
Re: How to Disable remote login
the 192.168.1.1 isn't remote access. Its local access meaning on your network.
Remote access is access external to your network.
Message 2 of 5
All Replies
Guru
Message 2 of 5
antinode
Guru
   Is that accurate?  Firmware version?
> with wifi on I can login to admin via 192.168.1.1 [...]
   Define "remote".
   What makes you think that your "my phone" is "remote" when you're
"using my phone with wifi"?  Or that any "remote" device could
communicate with your router at a private address like "192.168.1.1"?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Remote
Management".
   Then, using your cellular-telephone data connection rather than a
wireless connection to your own router, try again.
Message 3 of 5
008MB
Right,  I mistakenly said "Remote Access"
I have a linksys router and I can block admin access via wifi, so, how do I do this on the R6230?
Mike
Message 4 of 5
antinode
Guru
> I have a linksys router [...]
   Thanks for the detailed description.
> [...] and I can block admin access via wifi, so, how do I do this on
> the R6230?
   Not an option which I've seen on any Netgear router.  The "admin"
password is the only restriction I've seen.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1686 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
