- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WAC510 Firmware Version 9.9.0.10 "Firmware Upgrade server not reachable."
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upgrading to WAC510 Firmware Version 9.9.0.10
from WAC510 Firmware Version 9.0.8.6
causes "Firmware Upgrade server not reachable."
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WAC510 Firmware Version 9.9.0.10 "Firmware Upgrade server not reachable."
Wed Aug 2 22:09:04 EDT 2023 configd[2361]: Update IP in FP_DB failed 19427 Wed Aug 2 22:09:03 EDT 2023 configd[2361]: Update IP in FP_DB failed 19427 Wed Aug 2 22:03:59 EDT 2023 configd[2361]: Backup of /var/config is carried on Wed Aug 2 22:03:08 EDT 2023 wifidog[9831]: There was a problem pinging the auth server! Wed Aug 2 22:03:08 EDT 2023 wifidog[9831]: Timed out reading data via select() from auth server
- Mark as New
- Bookmark
- Subscribe
- Permalink
How are you going about it? Manual update is the most reliable.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual
Manually Download Firmware and Upgrade the Access Point
For more advice on your device, try the appropriate section:
Business Wireless - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have the same problem. Updating two units from 9.6.0.12 (We reverted to old firmware because later updates caused bad behavior with our access points!). We've had repeated issues upgrading firmware with these Netgear access points. We made the mistake of thinking that by this point, with a 9.9.x version upgrade things might have been fixed.
After firmware upgrade, when I click the button that says "Check for Updgrade" from the Dashboard, both units show the error message that the firmware upgrade server cannot be reached.
Last night, I upgraded 2 units. The first appeared to upgrade fine. The second one showed a message at reboot about there being a problem with the firmware update. No further details. That's when I tried to see if I could reflash the firmware by clicking the "Check for Upgrade" button again, but then saw the mentioned error message.
The thing is, despite the error message, the second unit rebooted into the new firmware and is running the new version anyway. WTF? Why would it boot into a new firmware when it detects a problem upgrading to the new firmware? Shouldn't it have booted into the backup firmware? Or could the unit have updated the firmware fine, but the error is actually related to the issue of not being able to access the upgrade server, which is why it didn't boot into the backup firmware? But if that were the case, why didn't we see the same error about a bad firmware upgrade with the other unit, since both units say they can't access the firmware upgrade server?
For the unit that did NOT show any error message after the firmware update, this morning, suddenly users couldn't access wifi via the access point. Wifi was confirmed to be functional last night. Suddenly saved Wifi passwords would not work to connect to the access point. I had to manually reboot the WAC510 to restore wifi access.
Gotta say, with these repeated Netgear access point issues, they are not going to be deployed in our business for long. We need reliability and stability, not spontaneous and repeated headaches...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not possible from a tablet, but thanks for the reminder on manual upates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WAC510 Firmware Version 9.9.0.10 "Firmware Upgrade server not reachable." Is now Reachable
Resolved, just installed F/W Version 9.9.1.3 Released on 9/4/2023
Was not a F/W Failure, but the Upgrade Server was just not available. It is now.
https://kb.netgear.com/000065799/WAC505-WAC510-Firmware-Version-9-9-1-3
New Features and Enhancements:
- Improved client notification alerts.
Bug Fixes:
- Fixes an issue where sometimes Insight throws a “Validation failed” message for a freshly onboarded AP.
- Fixes various issues in the External Captive Portal feature.
- Fixes an issue where clients connected to a captive portal SSID might not see the splash page for authentication when the VLAN of the SSID is the same as the AP management VLAN.
- Fixes an issue where AP starts operating on 802.3af power even when powered with an 802.3at or 802.3bt switch.
- Fixes an issue where the captive portal splash page is not displayed when a client connects to an SSID using WPA2 Enterprise security.
- Fixes an issue where active user sessions are not logged out when location-wide device credentials change.
- Fixes an issue when Syslog configuration disabled by the user get enabled again after AP reboot.
- Adds system stability improvements.
