Orbi WiFi 7 RBE973
Reply
Using a GS105v4 with a GS108
CJT-80
Follower
Hi there,
I currently have a GS105 (5 port unmanaged switch) which I am very happy using, but I wondered if I want to expand my switch capacity can I use the GS105 with a GS108 (8 port unmanaged) without any issues?
The 108 would take it's "input" from my ISP router and feed it to a PC/NAS/VOIP and a few other devices and also 1 feed to the GS105 which would have AV tech, TV/AMP/STB/BluRay
Would this work?
Thanks in advance.
Smiley Happy
Model: GS2108|8-port 10/100/1000 Mbps Gigabit Ethernet Switch
Message 1 of 3
Accepted Solutions
JohnRo
NETGEAR Employee Retired
Re: Using a GS105v4 with a GS108
Hi CJT-80,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
Message 3 of 3
All Replies
JohnRo
Hello CJT-80,
Welcome to the community!
I don't see any issue with the setup. As long as they are behind the router, IP addressing should be okay. Adding the GS108 will extend the number of ports you can use.
Let me know if you have more questions.
Thanks,
Message 2 of 3
JohnRo
Hi CJT-80,
Thanks,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2893 views
  • 2 kudos
  • 2 in conversation
Announcements
