emd1's avatar
emd1
A disk failure will render this volume dead
Hello,
I have a ReadyNas NV+ [RND4450] that was complaining of "Reallocated sector counts" on disk 4. I have 4 Seagate ST31500341AS [1397 GB] installed and always kept a spare drive on the shelf in case of failure, so I decided to swap this drive and let the array rebuild itself. I shut down the device, pulled and swapped the 4th disk and powered back up, this is what I got in the logs:
Wed Feb 6 08:44:34 EST 2013 System is up.
Wed Feb 6 08:43:30 EST 2013 RAID sync started on volume C.
Wed Feb 6 08:27:56 EST 2013 Powering off device
Wed Feb 6 08:27:55 EST 2013 Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off...
The sync was progressing, I kept the FrontView page on the process and saw it at at least 12% before I got the message in Volumes:
Configuration: X-RAID (Expandable RAID), 4 disks
Status: Not redundant. A disk failure will render this volume dead.
"Resync Volume" is grey so that option is not available to me.
At this point I called it a day and went home hoping it would come back to the resync process as I had seen some messages here stating it could take quite a while. Well over the weekend seems like enough time for anything and it still shows the same message about any new failure will render it dead. I have the important data backed up so that is not a big problem but I would like to know if there is any way out of this to get everything back to normal short of reinitializing everything and starting over.
Thanks
emd
  • You had 1 disk fail, but what is the status of the other disks? Are they bad, too? If they are also bad, you can have problems resyncing your volume. As soon as it starts to sync and hits a bad part of the disk, you could expect the drive to stop resyncing and leave it non-redundant as it only partially restriped the data onto the disk.
    Could you post some logs online that we may look at? All of the logs preferred.
  • As far as I can tell they are fine, see attached image link for screenshot of the Volumes page in ReadyNAS. I can access all data fine, it's just reporting that it will fail if I lost a drive.
    http://imgur.com/Bc1GIdE
    Drive 4 was showing many reallocated sectors, this is why I swapped in my spare drive.
    Which logs would be needed, If I dump all the logs it's about 7.3 meg compressed I think, so is there something specific? Or a place to post such a large file set?
    Thanks!
    emd
  • here is disk_smart.log I'm hoping that is what you wanted.
    ***** smartctl output for hdc *****
    smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build)
    Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
    === START OF INFORMATION SECTION ===
    Model Family: Seagate Barracuda 7200.11
    Device Model: ST31500341AS
    Serial Number: 9VS1ADZN
    LU WWN Device Id: 5 000c50 0110ec61b
    Firmware Version: CC1H
    User Capacity: 1,500,301,910,016 bytes [1.50 TB]
    Sector Size: 512 bytes logical/physical
    Device is: In smartctl database [for details use: -P show]
    ATA Version is: 8
    ATA Standard is: ATA-8-ACS revision 4
    Local Time is: Tue Feb 12 08:53:29 2013 EST
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    General SMART Values:
    Offline data collection status: (0x82) Offline data collection activity
    was completed without error.
    Auto Offline Data Collection: Enabled.
    Self-test execution status: ( 0) The previous self-test routine completed
    without error or no self-test has ever
    been run.
    Total time to complete Offline
    data collection: ( 617) seconds.
    capabilities: (0x7b) SMART execute Offline immediate.
    Auto Offline data collection on/off support.
    Suspend Offline collection upon new
    command.
    Offline surface scan supported.
    Self-test supported.
    Conveyance Self-test supported.
    Selective Self-test supported.
    SMART capabilities: (0x0003) Saves SMART data before entering
    power-saving mode.
    Supports SMART auto save timer.
    Error logging capability: (0x01) Error logging supported.
    General Purpose Logging supported.
    Short self-test routine
    recommended polling time: ( 1) minutes.
    Extended self-test routine
    recommended polling time: ( 255) minutes.
    Conveyance self-test routine
    recommended polling time: ( 2) minutes.
    SCT capabilities: (0x103f) SCT Status supported.
    SCT Error Recovery Control supported.
    SCT Feature Control supported.
    SCT Data Table supported.
    SMART Attributes Data Structure revision number: 10
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
    1 Raw_Read_Error_Rate 0x000f 112 099 006 Pre-fail Always - 48074302
    3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0
    4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 15
    5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 7
    7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 163401398
    9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 33132
    10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
    12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 15
    184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
    187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
    188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1 (1, 1)
    189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 105
    190 Airflow_Temperature_Cel 0x0022 069 053 045 Old_age Always - 31 (Min/Max 29/34)
    194 Temperature_Celsius 0x0022 031 047 000 Old_age Always - 31 (0 16 0 0 0)
    195 Hardware_ECC_Recovered 0x001a 033 015 000 Old_age Always - 48074302
    197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
    198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
    199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
    240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 265295834939756
    241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2914827473
    242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 240728476
    SMART Error Log Version: 1
    No Errors Logged
    SMART Self-test log structure revision number 1
    No self-tests have been logged. [To run self-tests, use: smartctl -t]
    SMART Selective self-test log data structure revision number 1
    SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
    Selective self-test flags (0x0):
    After scanning selected spans, do NOT read-scan remainder of disk.
    If Selective self-test is pending on power-up, resume after 0 minute delay.
    ***** smartctl output for hde *****
    Serial Number: 9VS1D6M3
    LU WWN Device Id: 5 000c50 0111ea1b1
    ATA Version is: 8
    been run.
    data collection: ( 609) seconds.
    command.
    power-saving mode.
    1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 233536637
    4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 14
    5 Reallocated_Sector_Ct 0x0033 098 098 036 Pre-fail Always - 118
    7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 159964006
    9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 33058
    12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 14
    189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 267
    190 Airflow_Temperature_Cel 0x0022 064 049 045 Old_age Always - 36 (Min/Max 34/39)
    194 Temperature_Celsius 0x0022 036 051 000 Old_age Always - 36 (0 16 0 0 0)
    195 Hardware_ECC_Recovered 0x001a 037 019 000 Old_age Always - 233536637
    240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 138701673890081
    241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1472814106
    242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3139649318
    No Errors Logged
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
    ***** smartctl output for hdg *****
    Serial Number: 9VS1DPGM
    LU WWN Device Id: 5 000c50 0111dd4a8
    ATA Version is: 8
    Local Time is: Tue Feb 12 08:53:31 2013 EST
    been run.
    command.
    power-saving mode.
    1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 215951700
    5 Reallocated_Sector_Ct 0x0033 099 099 036 Pre-fail Always - 44
    7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 134505339
    9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 33063
    188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
    189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 231
    190 Airflow_Temperature_Cel 0x0022 064 051 045 Old_age Always - 36 (Min/Max 34/39)
    194 Temperature_Celsius 0x0022 036 049 000 Old_age Always - 36 (0 16 0 0 0)
    195 Hardware_ECC_Recovered 0x001a 036 021 000 Old_age Always - 215951700
    240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 133217000653095
    241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1216653438
    242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2999430668
    No Errors Logged
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
    ***** smartctl output for hdi *****
    Serial Number: 9VS2W5FA
    LU WWN Device Id: 5 000c50 019abfd7a
    ATA Version is: 8
    Local Time is: Tue Feb 12 08:53:32 2013 EST
    been run.
    command.
    power-saving mode.
    1 Raw_Read_Error_Rate 0x000f 100 100 006 Pre-fail Always - 11443
    4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 3
    5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
    7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 488260
    9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 144
    12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 3
    189 High_Fly_Writes 0x003a 099 099 000 Old_age Always - 1
    190 Airflow_Temperature_Cel 0x0022 068 066 045 Old_age Always - 32 (Min/Max 22/34)
    194 Temperature_Celsius 0x0022 032 040 000 Old_age Always - 32 (0 22 0 0 0)
    195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 11443
    240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 27891517620368
    241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 571466798
    242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 248
    No Errors Logged
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
  • Would perhaps a graceful restart of the box get the resync started again? I am a bit leary of doing this at this point.
    emd
  • I decided to try gracefully rebooting the device and this appears at least for the time being to have gotten things moving again. The device is now in the resync process at 22%, I just hope it continues. Once it does it looks like there is an update that I can install for firmware so I will get that out of the way as well.
    http://imgur.com/xYt6mvN
    thanks
    emd
ProSupport for Business
