× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Backup between two ReadyNAS units on same network
mbender
Follower
Folks,
I am trying to automate a back up one ReadyNAS unit to another over my house network. After searching some of the documentation, I decided to set up an Rsync backup.  I have configured the ReadyNAS 312 to reach into the Pro 2 unit for a backup of a single folder (with subfolders).  In the backup details, I have the IP, source etc. populated, and did a "test connection" to ensure it could see the Pro 2 unit.  The first backup (that night) was successful (via the log entry) but every backup since then has failed (the backup is set for once a week operation).  The error I receive in the log details is as follows (I believe it is the same error for each log entry) :
Backup Job Name: Backup from KD6NOT NAS device
Backup Job Type: Incremental
Protocol: rsync
Backup Source: [remote:rsync]/192.168.1.9::backup
Backup Destination: [Backup]/
Backup Start Time: Sat Jul  9 2016 16:31:38
Backup Finish Time: Sat Jul  9 2016 16:31:57
Backup Status: Fail: failure during copy.
Failed to run rsync, return rc 5888 (23)
'rsync' command returns rc=5888
rsync: readlink_stat("/Heidi/Pictures_07Sep15/Geology 2/P4170041.JPG" (in backup)) failed: Input/output error (5)
I am new to the backup process (I have been doing it manually every few weeks for years via a painful copy/paste) and am not immediately sure where I went wrong.   Any thoughts?
Thanks in advance for any help,
Mark
Model: ReadyNASRNDP2110|ReadyNAS Pro 2,RN31200|ReadyNAS 300 Series 2- Bay
Message 1 of 2
Guru
Re: Backup between two ReadyNAS units on same network
This looks like a file permissions problem.
Try resetting the permissions for all files in the share on both the RN312 and the pro-2 (on the pro-2 it should be on the "advanced options" tab for the share).
If that fails, try copying the jpg somewhere else, and delete it from both the source and the backup, and run the backup again.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2588 views
  • 0 kudos
  • 2 in conversation
Announcements
