× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Backup from 516 to 316 (or between any two os6 devices)
x219c
Luminary
I've got my 516 setup just the way I'd like using xraid on raid 6. I have nearly mirrored this in a 316. Same size drives, raid 6, but no apps or anything.
How can I do a full backup from the 516 to the 316. I would like to not only preserve the actual shares (that, I can figure out) but also the apps and their data, The Plex DB, an SQL database... etc. All stored in the hidden folders.
Upon searching, I found much about migrating from older systems and such, but not much with this in mind. Ideally, I envision the NAS going down (let's say 3 drives failed, however unlikely)... I buy new drives, get it all ready again... Then press restore, and it copies everything back, just as it was. That, or something very similar, so that I'm not trying to figure out how I had things working together before the crash. Is there a way to do this?
Model: RN51600|ReadyNAS 516 6-Bay Diskless
Message 1 of 7
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: Backup from 516 to 316 (or between any two os6 devices)
Backing up the system is a feature for legacy ReadyNAS. You can backup the ReadyNAS Configuration under System > Settings > Configuration Backup. This doesn't backup the config or data for apps.
The apps config and data is stored in the hidden .apps share on the main data volume e.g. /data/.apps
Apps should store all their config and data in there, but it's possible some may not.
It is good that you are backing up your data. After all, no important data should be stored on the one device.
Message 4 of 7
All Replies
x219c
Luminary
Just spitballing... Would I create a backup job with the source as "/" and the destination as a share on the 316?
Message 2 of 7
x219c
Luminary
I've tried "Backup System" in replicate, where it tells me that the source system doesn't support this. I also attempted what I suggested above.. That's met with another error indicating that the source and destination can't be the same. (the aren't)
I can backup the shares, but I'd like to get the rest, if possible.
Message 3 of 7
mdgm-ntgr
Message 4 of 7
x219c
Luminary
Thanks mdgm, I guess the million dollar question is: if I do backup /data using the backup tab, will it catch the apps folder too? As a follow-up, it is possible to backup the data folder using the backup tab, right?
Message 5 of 7
mdgm-ntgr
Yes. I just tested this and it works.
Note that if somehow an app stores some data not on the data volume that wouldn't be backed up.
Message 6 of 7
x219c
Luminary
That sounds good to me. Thanks!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2327 views
  • 1 kudo
  • 2 in conversation
Announcements
