× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Booting hangup after new drive
Guru
Re: Booting hangup after new drive
muddauber wrote:
StephenB, You commented "There is a checkbox that you can check before you insert the 4th drive that
lets you add it for redundancy, not more capacity. If you check that box, you'll end up with xraid dual-redundancy/raid-6."
Where is that checkbox?
I also told you to use XRAID, not flexraid. I don't believe that checkbox applies to flexraid (but am not sure).
Select Volumes, and then Raid Settings and you see if the checkbox is there.
If you want flexraid, you might need to reset again with 4 disks in place, and chose Raid-6.
Message 26 of 28
muddauber
I did not see an option for RAID5 with XRAID, so I chose FLEXRAID because it showed the option of
RAID5.
After the drives synced and I added 4th drive, it showed RAID5 "redundant",
and when I added 4th drive it gave me option of
__ Add To Volume __Make Hot Spare
I chose Make Hot Spare.
So this is not going to be RAID6?
Message 27 of 28
Guru
RAID5.
No. A "hot spare" is something else.
If you had simply installed xraid with three drives you would have had single-redundancy - which is RAID-5.
To get where you want to go you need to do another factory reset.
Message 28 of 28
Top Contributors
Discussion stats
  • 27 replies
  • 4828 views
  • 0 kudos
  • 6 in conversation
Announcements
