× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
CIFS files with owner field blank
bald_bloke
Hi
I have a ReadyNAS Pro Business Edition running 4.20. One of the users (windows XP machine) occasionally seems to be able to create files and directories that have no owner. That is, the owner field is completely blank. This leaves the file / directory in a state that is inaccessable using windows explorer.
I have tried using the share/advanced options to set ownership / permissions to all files but this does not fix the problem.
How can I recover from this?
Message 1 of 3
ReadySECURE
Apprentice
Re: CIFS files with owner field blank
How have you tried using the set ownership and permissions to all files?
Have you tried placing the ownership and permissions to "nobody" and "nogroup" (without quotes)?
When you are performing the above, make sure that you are checking the box that says "set ownership and permissions to the above...."
Message 2 of 3
bald_bloke
Hi, I just tried what you suggested and set the owner to 'nobody' rather than the name of the share which is the default value. This appears to have fixed the problem.
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 934 views
  • 0 kudos
  • 2 in conversation
Announcements
